Tech question - Air injection - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-05-2012, 03:34 PM   #1 (permalink)
Newbie
Main Motorcycle: 2013 Thruxton 900
Hi All,
I'm new here. I recently bought a new Brooklands Green Thruxton which is still to be delivered. It will be fitted with Triumph TOR exhausts.
Question:
Does anyone know what exactly the air injection system does? And better: do you advice me to have it removed by the dealer before the bike will be "set free"
Thanks!
All the best, Luc
The Netherlands
ThruxtonCafe is offline   Reply With Quote
Old 11-05-2012, 03:42 PM   #2 (permalink)
Other Motorcycle: 2007 Suzuki DL1000
Extra Motorcycle: 2002 KTM 300 EXC
I don't remember exactly what this does, but I do know that it is some type of smog control device and was blamed for lots of blue pipes.
I have a carbureted Thruxton, so my experience may not be exactly as yours but; removing the air-injection did make it run better. If you have TORs, it would probably be a good idea to get an airbox removal or do the airbox mod.
Also, for the air injection elimination, I don't have a lot of mechanical ability, but it was an easy job for me. Basically the "kit" is a bunch of plugs so you can get rid of a bunch of plumbing.
Chewbaca is offline   Reply With Quote
Old 11-05-2012, 03:44 PM   #3 (permalink)
Main Motorcycle: 05 Bonneville Black
Llamacide's Avatar
Search the site... There is plenty of info about the AI system.
It's basically an emissions feature that takes excess air/fuel and returns it to the system to be vaporized... A side effect is extra heat in the header pipes which will cause the chrome to blue over time.... A lot of guys remove it before that happens...
The other answer to your question is I would be surprised if any dealer would remove the AI system as it would be illegal for them to tamper with the emission system on the bike... You would likely need to do it yourself or find someone to help you out....
Llamacide is offline   Reply With Quote
Old 11-05-2012, 04:08 PM   #4 (permalink)
Main Motorcycle: '13 Thrux
Hmm, I originally wanted to get my dealer to install the BC efi upgrade kit, I'll have to check if they will now...
On the subject of bluing pipes though, does anyone know if blue pipes are still able to be ceramic coated, or should they be coated before bluing?
Locky is offline   Reply With Quote
Old 11-05-2012, 04:12 PM   #5 (permalink)
Dealers here didn't seem to have any issue with removing the AI, or working on a bike that had the AI removed. I know that CA does have stricter emissions policies, though...
Old 11-05-2012, 04:29 PM   #6 (permalink)
Llamacide's Avatar
Well I must admit, I do live in CA but I don't have any first hand knowledge of a dealer not doing it but I assumed since it was emission specific it would likely be beyond what a dealer could legally do... Someone could certainly correct me on that.
Old 11-05-2012, 05:24 PM   #7 (permalink)
Main Motorcycle: 2007 Triumph Thruxton
andrewp's Avatar
all three dealers in my area have no problem removing it but honestly, if you can read instructions and have a set of tools, you can do it in about the time it takes to enjoy a beer
*however, it might affect the map you use on an efi bike? not sure.
andrewp is offline   Reply With Quote
Old 11-05-2012, 06:56 PM   #8 (permalink)
Main Motorcycle: 2010 ninja 250r
ratlab's Avatar
Other Motorcycle: triumph thruxton
Extra Motorcycle: 2006 gsxr 1000
after dec.2012 you can't even get a dealer to sell or install a aftermarket pipe,let alone do anything emissions related-power commander, air filters etc. in calif.
ratlab is offline   Reply With Quote
Old 11-05-2012, 10:44 PM   #9 (permalink)
Main Motorcycle: 06 Thruxton
Other Motorcycle: 05 Thruxton
Extra Motorcycle: 06 sporty 1200
Locky
My pipes were blue for a year or so before I had them ceramic coated black. That was about 5 years ago and they still look good😀
Sent from my iPhone using MO Free
TJRCARRILLO is offline   Reply With Quote
Old 11-06-2012, 12:39 AM   #10 (permalink)
Originally Posted by TJRCARRILLO View Post
Locky
Thanks mate,
Who did you get to do them?
Tech question tri955i Daytona Deliberations 4 04-02-2008 05:24 PM
Tech Question.. 1trumpetdood Daytona Deliberations 4 06-23-2007 01:17 AM
Newbie question about air injection PeteIllingworth Twins Technical Talk 3 11-21-2006 03:50 PM
Air Injection question Stuie Twins Talk 5 05-02-2006 08:53 AM
Fuel Injection Question Mancha Twins Talk 9 10-18-2005 11:23 AM
