Tech question - Air injection - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!SportbikeTrackGear
Old 11-15-2012, 03:31 PM   #21 (permalink)
Main Motorcycle: 06 Thruxton
Other Motorcycle: '69 Bonneville
Extra Motorcycle: '71 Bonneville
No, you are not the only one. Although I sort of prefer a little closer to a straw or gold color. But if it's got some blue, well that's sort of the way it's supposed to be.
Art.
BirdoPrey is offline   Reply With Quote
Old 11-17-2012, 08:09 AM   #22 (permalink)
Main Motorcycle: 2013 Thruxton 900
I don't mind it either, but this chemist/motorcycle enthusiest I work with keeps telling me (in his auzzie accent) "Ah, yer runnin' way lean. An that colour shows the chrome turning to chromium oxide, which will flake off over time." I'm not a chemist (thank god), and have no comeback for this. I deleted the AI mainly to shut him up.
Grimsby53 is offline   Reply With Quote
Old 11-17-2012, 08:06 PM   #23 (permalink)
I'm fine with the bluing too. The bike looks like I ride it.
Marty
Old 11-17-2012, 11:27 PM   #24 (permalink)
Main Motorcycle: just one? no fair
Danbuc's Avatar
Other Motorcycle: Ducati 748
Extra Motorcycle: Ducati 853R :P
Kill it with fire! And if not in Cali, pull all the junk off the bike too. Easy enough and cleans up the bike and pulls a little weight off too which is never a bad thing.
"It's not leaking oil, it's just sweating from all the horsepower!"
Mods:Arrow 2-1, BC FEK, BC indicators, BC Quick release cover screws, BC AIRK, CRG mirrors, LSL Rearsets, black 'chazzos', custom 'brushed finish' headlight, NH Damper.
Danbuc is offline   Reply With Quote
Old 11-18-2012, 05:01 PM   #25 (permalink)
El Moderatore
Main Motorcycle: 2007 Bonneville LeMans
Calliway's Avatar
Other Motorcycle: 1972 CB350
Extra Motorcycle: 1977 GS400
removing the AI won't stop the bluing, only a double walled header will. removing the AI will however, stip the backfiring that you will get with your TORS and AI on. You will need to use an aftermarket map editor to disable the AI after you remove it otherwise you will get a check engine light on your dash.
Calliway is offline   Reply With Quote
Old 11-19-2012, 07:22 AM   #26 (permalink)
No check engine light for me! No re-map needed. I followed the instructions in this thread:
http://www.triumphrat.net/twins-tech...nny-thrux.html
Basically, you wire a 50-Ohm resistor where the solenoid was. The computer can't tell the difference.
Old 11-20-2012, 12:15 AM   #27 (permalink)
El Moderatore
Calliway's Avatar
Perfect and great link.
Tech question tri955i Daytona Deliberations 4 04-02-2008 05:24 PM
Tech Question.. 1trumpetdood Daytona Deliberations 4 06-23-2007 01:17 AM
Newbie question about air injection PeteIllingworth Twins Technical Talk 3 11-21-2006 03:50 PM
Air Injection question Stuie Twins Talk 5 05-02-2006 08:53 AM
Fuel Injection Question Mancha Twins Talk 9 10-18-2005 11:23 AM
