EFI Map - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-03-2012, 10:15 AM   #11 (permalink)
Main Motorcycle: 2010 Thruxton
Carlcampion's Avatar
Hi guys, I have a 2010 with the analog gauges, can I use a map that is made for a 2011 with LCD gauges .?
Carlcampion is offline   Reply With Quote
Old 11-03-2012, 11:46 AM   #12 (permalink)
Main Motorcycle: 2011 Thruxton
From what I found I don't think so. You can only use maps that works for analog gauges. I also read that you can take an analog map and then transcribe the map info from the efi map over to the analog. I never had to do that so I can't guarantee this is good.
tkl999 is offline   Reply With Quote
