Sorry I can't answer your question, but if your stand is like mine, which I got in the mid 90s for my Ducati, using it for the Triumph should be a real experience. My Ducati weighed much less than the Triumph and it was still very difficult to lift. With the extra weight - I'd think you'd bust a gut getting it overcenter. This photo below isn't my stand - but it's the same design. (Note the lifting arm is shown installed backwards)
Hopefully they changed their design so it lifts easier.
Jim
Originally Posted by tkl999
I called Pitbull and they said that a Thruxton uses adapter pin #1 and they stated they had no compliants about it not fitting. I have a 2011 Thruxton and I have a Front under the yoke Pitbull stand that I used to use on my Hypermotard. I want to now use it on my Triumph. Anyone know the correct adapter? I did a search and some say that adapter pin #1 didnt fit correctly.
