2013 Brookland Green Thruxton Mods - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGear
Old 11-04-2012, 10:51 AM   #21 (permalink)
Main Motorcycle: 2013 Triumph Thruxton
Other Motorcycle: 1966 BSA Lightning
Not to be too much of a geek about this, but what brand/type wrench did you use? I've got a standard Sears Craftsman 13mm open end wrench, and I'm thinking it would open up and round the bolt head before it would loosen it.. Did you use a fancy SnapOn wrench or something like that?
JasonRP is offline   Reply With Quote
Old 11-04-2012, 10:52 AM   #22 (permalink)
Main Motorcycle: 2013 Thruxton 900
Other notes on the AI delete:
The instructions that came with the NB kit are specific to the carb'ed Bonnie's. I was pretty confused at first, but I found this thread that sorted it out:
http://www.triumphrat.net/twins-tech...nny-thrux.html
There's a link in that thread to another that explains removing the tank on an EFI bike pretty well. I also didn't realize until I read that thread that I needed to go get the 50-ohm resistor and wire that in, but that was pretty easy, and Radio Shack had the part. Some heat-shrink and a zip-tie made it look factory. I'm surprised there isn't a "deluxe EFI eddition" AI kit that comes with a plug-in resistor for the factory plug. At the point where I realized I'd need to borrow a car for the trip to RS, I would've paid another $30 to have a plug-in solution an be done with it.
Grimsby53 is offline   Reply With Quote
Old 11-04-2012, 11:04 AM   #23 (permalink)
I used a Craftsman 13mm combination wrench, and a couple sharp wraps with a rubber mallet. In my experiance this trick works great on stubborn fasteners, or those where the wrench engagement is less than ideal. Ymmv.
Old 11-04-2012, 03:40 PM   #24 (permalink)
Main Motorcycle: 2010 Thruxton
artful bodger's Avatar
Other Motorcycle: 1942 BSA
I am liking the looks of the green Thruxtons. They look nearly as fast as the red ones, but only nearly!
artful bodger is offline   Reply With Quote
Old 11-18-2012, 11:57 AM   #25 (permalink)
Main Motorcycle: Suzuki GSF1250SA
ed95206's Avatar
Other Motorcycle: 2013 Thruxton Brkland Grn
Black BC Preds
ed95206 is offline   Reply With Quote
Old 11-18-2012, 12:11 PM   #26 (permalink)
Newbie
Main Motorcycle: Haven't Decided Yet
Originally Posted by ed95206 View Post
Black BC Preds
That seals the deal... I know what my next bike is going to be!
NELS0N is offline   Reply With Quote
2013 Thruxton, Brookland Green bzoeller Club Cafe' 62 04-10-2013 01:06 AM
New 2013 Thruxton color will be "brookland green" Scrambler900 Club Cafe' 97 10-22-2012 10:33 PM
New 2013 Thruxton...Brookland Green bzoeller Twins Talk 23 08-14-2012 04:19 PM
2013 Thruxton colors - green, black Scrambler900 Club Cafe' 5 05-19-2012 11:24 PM
Results of Green Cam and other mods. Puff98TBS Hinckley Classic Triples 9 04-07-2011 10:23 AM
