"Ignition cooling"??? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
SportbikeTrackGearNew BonnevilleHonda Powersports
Old 09-26-2005, 01:39 AM   #1 (permalink)
Okay, so I'm ig'nant........
But I presume that finned box below our headlamp is part of the "ignition."
Have I compromised the cooling to said 'ignition' with the recent installation of my Bikini fairing from Omar's?????
- 'Rider' -
Click here for a view of my Member's Album.
FattRat is offline   Reply With Quote
Old 09-26-2005, 01:46 AM   #2 (permalink)
Hard to tell, looks like it still gets some air. You could probably trim some off the bottom, improve air fow and not hurt the looks. If it was mine I would.-T1
have fun-ride often!
thruxtonone is offline   Reply With Quote
Old 09-26-2005, 03:49 AM   #3 (permalink)
Favourite Bike: Triumph 955 Sprint ST
cal6n's Avatar
Other Motorcycle: Triumph Bonneville
Extra Motorcycle: Ducati Pantah Special
Hey Pat.
That's the voltage regulator for the charging circuit. I don't reckon you'll have any cooling issues. Ducati put their's under the fairing.
Cal
cal6n is offline   Reply With Quote
Old 09-26-2005, 10:07 AM   #4 (permalink)
On 2005-09-26 01:49, cal6n wrote:
... Ducati put their's under the fairing.
...and Ducatis have plenty of charging/regulator issues
vikingdrvr
vikingdrvr is offline   Reply With Quote
Old 09-26-2005, 10:50 AM   #5 (permalink)
Aprilia sticks their one under the tail section plastic and they are dead reliable bikes.
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Old 09-26-2005, 12:02 PM   #6 (permalink)
Nothing to worry about. That's essentially the way it's set up on a Thruxton with the Triumph flyscreen.
So long, and thanks for all the fish!
DrEnglish is offline   Reply With Quote
Old 09-26-2005, 02:15 PM   #7 (permalink)
Thanks guys,
I already had to butcher that fairing to get it to fit..... I didn't wanna be bothered with it again.
- 'Rider' -
Old 09-26-2005, 10:02 PM   #8 (permalink)
It's not going to be a problem for you. I've had my quarter faring for 2K miles without any issue.
'03 Ducati 999 MP
'04 Triumph Thruxton
'05 Ducati 749S
'04 Ducati 998S FE
lenswerks is offline   Reply With Quote
Old 09-27-2005, 05:18 PM   #9 (permalink)
cal6n's Avatar
I was going to tear you a new one until I saw your rides! :-D I've had no issues with anything post eighties. These things will sink enough heat even in still air.
Cal
Old 09-27-2005, 06:15 PM   #10 (permalink)
[/quote]
[/quote]
I was going to tear you a new one until I saw your rides! :-D [/quote]
Actually, the only charging fault I've experienced with either of my Ducs (insert: me knocking wood!) was with the wiring itself. It's very light gauge with poor insulation that tends to melt through and short together or against the frame. My remark was based on the very numerous issues I've read about from other Ducati owners on the Ducati lists, it seems to be a non-stop issue. But thanks for going easy on me!
vikingdrvr
Cooling fan thaw Hinckley Classic Triples 6 02-03-2007 03:49 PM
cooling the engine rskeenan Trophy 0 10-04-2006 02:46 PM
remove ignition barrel from ignition switch? kanoa Classic, Vintage & Veteran 3 07-13-2006 01:50 PM
S4 Cooling fan BigPappa Triumph SuperSports 6 01-20-2006 02:55 PM
Cooling Fan Hinckley Classic Triples 6 04-27-2004 03:06 PM
