I got a set from a '97, I'm re-using my lowers. Is there a recommended fork oil weight, or have any of you with the F3 forks tried different weights? More importantly, do you know the volume specified by honda? I did measure & record the volume of oil that came out, I can figure a small loss for oil adhering to the springs & get pretty close, but if somebody already knows that'd be nice.
I'm nearly done polishing them... tons of sanding first. I'm also polishing my top triple clamp, gauge plate, clip-ons, and a few other odds & ends. (I previously polished the case, sprocket, and cam covers) I'm going to do something different with the headlight mounts, I hate those chrome cylinders that fit over the forks that the stock ones bolt to. I cut two nice clamps from the honda triple clamp, but I need to make two more from something else or... who knows what, maybe I'll just spring for aftermarket brackets.
Also, I'm going to fit some ZRX shocks, they're nearly identical in length & can be modified to be 5/8" shorter if desired. The lower bushing needs to be swapped with one of the thruxton's current shock bushings, but it looks to be strightforward from there. I'll make a detailed post with pics when I've got that done in case anyone else wants to go that route. -I've got a ZRX & love the suspension (never owned a full-on sportbike though) so I'm pretty optomistic about them. The thrux is lighter than the rex (I assume), and the shocks are a tad on the stiff side for the rex to begin with, so it won't be a "cushy" ride. But they're nice looking piggybacks with compression and rebound damping adjustment. And about $1,000 less than Ohlins. :wink:
Mr. Whatisit? That guy treats objects like women, man.
