GSX-R 1000 front end on a Thruxton. Surprisingly easy to do. - Page 11 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-23-2012, 10:48 PM   #101 (permalink)
Main Motorcycle: Cafe'd Bonneville SE
cashmore1985's Avatar
I want to do this. I'm really only posting here so my auto subscribe thing will pick it up. Bike looks amazing.
'09 Bonnie SE Blue and White
MODS- Lots of 'em
Host and Producer - Cafe Racer Podcast
www.caferacerpodcast.com
cashmore1985 is offline   Reply With Quote
Old 11-05-2012, 05:53 PM   #102 (permalink)
Main Motorcycle: '12 Thruxton
Machine shop got back triples today and figured I'd post images. When I have them installed on the bike I will post updates.
Nick
Triples
nbthrux12 is offline   Reply With Quote
Old 11-09-2012, 11:40 AM   #103 (permalink)
Main Motorcycle: just one? no fair
Danbuc's Avatar
Other Motorcycle: Ducati 748
Extra Motorcycle: Ducati 853R :P
Very cool, simple and clean. Perfect platform to mount some custom gauges to. What did they run if you don't mind me asking?
"It's not leaking oil, it's just sweating from all the horsepower!"
Mods:Arrow 2-1, BC FEK, BC indicators, BC Quick release cover screws, BC AIRK, CRG mirrors, LSL Rearsets, black 'chazzos', custom 'brushed finish' headlight, NH Damper.
Danbuc is offline   Reply With Quote
Old 11-10-2012, 12:33 PM   #104 (permalink)
Newbie
Main Motorcycle: ZX636, SV650
Would any of you be interested in a group buy?
If we could get between 5 and 10 orders the prices would get reduced significantly.
For example, these were the prices for an SV650 upper triple clamp at different order quantities:
1 $350.00
2 $350.00
3 $260.00
4 $260.00
5 $200.00
6 $200.00
7 $177.00
8 $177.00
9 $162.00
10 $162.00
The price comes down so much because every time the CNC machine is setup to make a part there is a one-off setup charge to set up the clamping jigs and fixtures, cutting tools and machine programming. Simply, the more parts you make the more parts you can share the price over.
You can email me at Scott9861@gmail.com if you have any questions.
Thanks
Nebula is offline   Reply With Quote
Old 11-10-2012, 12:52 PM   #105 (permalink)
Danbuc's Avatar
I would certainly be interested. I take it it's the more popular 50mm upper x 54mm lower fork tube diameters?
Old 11-10-2012, 11:21 PM   #106 (permalink)
Main Motorcycle: Thruxton
Other Motorcycle: 1979 Ducati 900SS
I had the LSL triple trees installed last month. Wider than stock and way stiffer with more stability. I think this fork is amazing now.
roadie is offline   Reply With Quote
Old 11-11-2012, 02:14 PM   #107 (permalink)
Newbie
The set I made a 50/53 but that can be changed easily.
The 50/53 is gor the 06-09 GSXR 600/750 which is the most popular for SV650 conversions anyway.
Old 11-12-2012, 11:42 AM   #108 (permalink)
Danbuc's Avatar
Thought they were 50/54. I gotcha.
Do you know what the center to center diameter is by any chance?
Curious if there's enough material to go 53/56 on them as well.
Are these using the stock stem pressed into them I guess?
Old 11-12-2012, 10:15 PM   #109 (permalink)
Newbie
Standard GSXR fork leg centers are 207mm.
My lower triple has 5.0 mm around the fork clamp, I wouldn't want to reduce that for the lower clamp that takes all the load. I would add 2.0 mm to maintain the 5.0mm for a 56mm fork leg.
I'll take the solid model to work and run an FEA on it and see what the max load is.
Old 11-13-2012, 01:12 AM   #110 (permalink)
Main Motorcycle: '05 Triumph Bonneville
Craigore's Avatar
Other Motorcycle: '51 Harley Panhead
Extra Motorcycle: '74 RD350
How can we use a stock front wheel with these forks?
Craigore is offline   Reply With Quote
Cheap, easy and surprisingly effective mod Forchetto Twins Technical Talk 44 09-19-2010 10:34 PM
gsxr 1000 front end conversion... performancefactor Daytona Deliberations 1 09-15-2009 09:06 PM
1000 mile trip 18 or 19t front? wannab Sprint Forum 20 08-31-2009 08:26 PM
Easy Front Indicator Mount TCL Twins Technical Talk 2 05-03-2007 08:39 PM
GSXR 1000 front brake conversion BulldogHooligan Speed Triple Forum 2 04-11-2007 12:30 PM
