Thanks to Mancha and others I have finally decided to install gaiters on the Thrux. Problem with me is all the instructions I have say "loosen the forks" or something similar. In fact the instructions that came with the gaiters state to loosen the 8mm bolts on the triple clamp, nothing more. I know the headlight bracket. caliper and front wheel have to come off, and I plan on doing one leg at a time, however, I'm thinking theres more to removing the legs/forks than just that one 8mm bolt on the clamp. Such as the handlebar clamp/bolt and the upper triple clamp bolt.
I plan on doing this over the weekend... Thanks!
BIR #167
"Welcome to All Things Scottish, our slogan is, if it's not Scottish, it's craaaapp!! Can I help ye?" - Stuart Rankin
