Progressive Insurance
britishcustomsAdvanstarMotorcycleShowsMotorcycle.combritishcustomsTriumphPerformanceUSABikeBanditTrident-Exhausts.comMotorcycle.com Classifieds!AmericanMotorcyclistAssociation
Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
ShopTriumph.com
Old 06-29-2005   #1 (permalink)
boboso's Avatar
During a ride yesterday I noticed a "clicking" noise at certain speeds. After playing around for a while trying to figure it out, I came to the conclusion it must be my helmet (Arai Signet Springer) as touching all zippers, visible and safe to reach bolts etc during the noise did nothing and it seemed "centered" in my head (much like stereo). No problems, I have owned a Ducati and am used to various noises...
On arriving home, I re-checked just to be sure... Found no source of the noise but did find my tach very loose (moves up and down approx. 1/4") and could see no signs of tightening up. I checked the two nuts on the back of the tach enclosure but they were as tight as I would secure anything on plastic.
Any thoughts? Is the loose tach normal? Do I need more cowbell?
BIR #167
"Welcome to All Things Scottish, our slogan is, if it's not Scottish, it's craaaapp!! Can I help ye?" - Stuart Rankin
boboso is offline   Reply With Quote
Old 06-29-2005   #2 (permalink)
Mine is loose too, seems like it just might be rubber mounted for vibration, not sure though
TonUpMike is offline   Reply With Quote
Old 06-30-2005   #3 (permalink)
didnt somebody here post about having to put some extra washers behind the screws in the "cup" of the tacho and speedo to get a bit more strength or lock ????
Dave67 is offline   Reply With Quote
Old 06-30-2005   #4 (permalink)
Same here. I tried to tighten it using the screws in the back, but after a while I got nervous about stripping the threads. It's still a little loose.
I can't see this being a coincidence, so I would assume that there is some reason why they have been left slightly loose.
curefan is offline   Reply With Quote
Old 06-30-2005   #5 (permalink)
Ditto..
I also have a cluck-cluck sound coming from the front over potholes and rough roads. Might be the tach?
UB
Ride fast - take chances
UncleBlue is offline   Reply With Quote
Did I loose something?? STRider Speed Triple Forum 8 04-23-2007 03:00 PM
Loose neck ! Anchorbend Twins Talk 1 10-18-2006 06:01 PM
Tach help? 3rd gear @ 35mph What's the tach read? JMart121 Twins Technical Talk 4 06-25-2006 06:56 PM
Loose Piston? HankQ Classic, Vintage & Veteran 3 09-05-2005 11:18 PM
Loose calipers? KenT140D Hinckley Classic Triples 1 08-02-2004 05:32 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
