Motorcycle.com
Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 06-28-2005   #1 (permalink)
im picking up a set for my thruxton - im assuming I'll need a set of the adaptor kits?
How do they install? I took off the bar end cover thats on there now - is there a way to get the internal threaded sleeve out, or do the CRG's bolt right into that?
[ This message was edited by: TheOwl on 2005-06-28 17:45 ]
TheOwl is offline   Reply With Quote
Old 06-28-2005   #2 (permalink)
Yes. I dremeled the CRG tabs, so I could just screw them and bolt on mirrors.
See earlier threads on this install and other ideas.
puck is offline   Reply With Quote
Old 06-28-2005   #3 (permalink)
Yes, get the adaptor kits, then ...
Take a look at my album, click on the photos. Under one of them are the instructions for mounting these mirrors.
You cut the end of the adaptor off with coping saw, then file smooth with emory board and it will butt right up to your bar end. You use the stock screws.
In other words, the adpators will bolt to the existing bar end internals - So remove nothing other than the stock end caps.
[ This message was edited by: lenswerks on 2005-06-28 19:48 ]
'03 Ducati 999 MP
'04 Triumph Thruxton
'05 Ducati 749S
'04 Ducati 998S FE
lenswerks is offline   Reply With Quote
Old 06-29-2005   #4 (permalink)
cool, thanks fellas!
Old 06-29-2005   #5 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
for a much cheaper solution buy a box of 7/8" diameter stainless fender washers (about $4) and just use a stack of them as an adapter. Buying the adapters is a waste of money
Mick...
Old 07-03-2005   #6 (permalink)
That's a good idea.
curefan is offline   Reply With Quote
Old 07-06-2005   #7 (permalink)
I took off the end caps, and used an aluminum shim and the exsisting bolt to attach mine to the stock bars. I had to trim a little off the inside of the mirror to make it sit flush, but it works really well.
"hell hath no fury like a woman scorn for sega"
customcafe is offline   Reply With Quote
Old 07-08-2005   #8 (permalink)
I'm trying to use the method suggested by thrux-ton-up. He said you just put Lockhart Phillips Flush Mount bar ends and attach the CRG's to them. Problem is I can't find any bar end in a 7/8 " outside diameter. Any advice?
05 Thruxton
05 R1200GS
Dunnester is offline   Reply With Quote
Old 07-08-2005   #9 (permalink)
Do the fender washer thing. Cheap and easy, you should be able to get them at an auto parts store.
have fun-ride often!
thruxtonone is offline   Reply With Quote
Old 07-08-2005   #10 (permalink)
Here they are. They are cheap - install with stock bolt - different colors available. JCW
Bar Ends
Heres what they look like on the bike.
[ This message was edited by: Thrux-ton-up on 2005-07-08 11:17 ]
http://www.triumphrat.net/memberalbums/data/500/thumbs/dragon1.jpg
John W.
  • 04 Thruxton – Graphite & Opal
  • 06 T100 – Black & Red
  • 05 T100 - Black & Opal - Project Bike
  • 51 T100 – Silver & Black
Thrux-ton-up is offline   Reply With Quote
LP bar ends ender Triumph SuperSports 2 04-22-2007 04:39 PM
CRG Clamp on mirrors or Bar ends? jh225 Speed Triple Forum 1 11-10-2006 02:08 PM
For those with CRG Bar End Mirrors... bluesock943 Club Cafe 8 09-26-2006 06:07 PM
Bar end weight/extension for CRG or Rizoma bar end mirrors? KAH24 Club Cafe 11 04-18-2005 05:33 PM
CRG Bar End Mirrors on S3 fwhite Speed Triple Forum 23 01-22-2005 12:41 PM
