Idle Adjustment and carb tuning on 2009 EFI Thruxton - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-12-2009, 03:36 PM   #1 (permalink)
Favourite Bike: Thruxton 09
BDTD's Avatar
Other Motorcycle: My legs
Hi,
i've been reading a lot on the forums about carb tuning and setting of the idle mix. None of the posts i've read thus far deal with the 2009 (2010 US) models.
I adjusted mine to run at about 800 - 900 rpm at idle when warm.
My questions are:
Can adjusting the idle mix (i used the little black adjuster beside choke) upset the performance of the bike at all ?
Do the new 2009 (2010 US) Thruxton's need carbs balanced ? I was under the impression that the carbs on these new EFI models were for show only ?
Cheers
2009 Thruxton Tornado Red with TORs, MAS Engineering FEK, LED Turn Signals, Oberon Racing Footpegs, Oberon Preload Adjusters
BDTD is offline   Reply With Quote
Old 11-12-2009, 04:46 PM   #2 (permalink)
Favourite Bike: Triumph Street Triple.
Other Motorcycle: Ibis Mountain bike.
The EFI models have fuel injectors inside those fake carb bodies.
Adjusting the idling speed doesn't affect the bike, but if you set it too low it won't charge the battery when idling.
The EFI is set up via computer by your dealer.
S.
2010 Street Triple. Black.
"Just because you're breathing doesn't mean you're alive"
Sp00ky is offline   Reply With Quote
Old 11-12-2009, 04:46 PM   #3 (permalink)
Favourite Bike: 2010 Thruxton 900
Bloggins's Avatar
Extra Motorcycle: BMW R26
Those are not carbs on your '09, they are throttle body fuel injectors. Anything you read about tuning carbs doesn't apply. Tuning on these bikes is accomplished using an electronic mapping device connected to the bikes ECU. Hope this helps.
Bloggins is offline   Reply With Quote
Old 11-12-2009, 04:52 PM   #4 (permalink)
BDTD's Avatar
Cheers guys thanks for the info.
Is 800-900rpm a decent idle speed when bike is warm or ideally should it be a bit higher than that when cold ?
Old 11-12-2009, 05:03 PM   #5 (permalink)
I usually set mine higher via the black adjuster and then let the ECM decide what it should be.
The ECM "learns" from it's sensors. My bike idles faster when very hot after a hard run, but that's not my problem...
I usually have my idle set around 1000 to 1100.
Having a higher idle speed ensures good charging of the battery, and it makes the bike easier to ride through slow traffic.
The downside is a bit of a *clunk* into first gear from a stop / start situation.
S.
Old 11-12-2009, 05:08 PM   #6 (permalink)
BDTD's Avatar
Talking
is that 1000-1100 rpm hot or cold ? i'm assuming hot ?
cheers spooky great advice
Old 11-12-2009, 05:47 PM   #7 (permalink)
Favourite Bike: 2007 Thruxton
Wait a sec. Doesnt the 09 EFI bikes need to do a throttle body sync? I know when I had my Yamaha, I used a carbtune II to do a throttle body sync on the bike.
tkl999 is offline   Reply With Quote
Old 11-12-2009, 05:48 PM   #8 (permalink)
Favourite Bike: 2009 thruxton
Mine idles at 1000-1100 when warm, Triumph spec is 1000 +- 50
rpm. On the scheduled maint chart the Throttle bodies are to be
adjusted every 6000 mile/1 year. This requires the "diagnosic tool".
I will probably just wait until one year , or I get pipes.
Mike A.
09 Thruxton
SMR, SLT
easttex is online now   Reply With Quote
carb adjustment/idle question 1759AG Classic, Vintage & Veteran 32 04-02-2010 06:24 PM
2009 Bonnie SE Idle Adjustment Knob martines.muffins Twins Technical Talk 13 09-07-2009 05:31 PM
fine tuning the idle mix for the carb novice. stewart57 Twins Technical Talk 1 04-23-2009 11:36 AM
Idle Problems... Idle Adjustment.... Toystoretom The Rocket Science Forum 31 04-10-2006 01:30 PM
Thruxton carb adjustment Club Cafe' 7 01-02-2005 06:36 PM
