latest tail light mod - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!New BonnevilleMotorcycle.com
Old 10-22-2009, 07:38 PM   #1 (permalink)
I lost one of the plastic plugs from the frame tube... looked like a good place to stick a flasher! I am using the Run/Stop/Turn signals combined, I bought some 3/4" light sockets and trimmed them to fit in the tube, and a red LED bulb. about $20 for the fix.
I had the tail lights mounted by the rear springs, I thought if I ever used saddle bags I would have to move them anyway.
jt...
jtjansen is offline   Reply With Quote
Old 10-23-2009, 11:48 AM   #2 (permalink)
Randy01's Avatar
Looks great. Much cleaner look than almost all of the FEKs out there. Where did you get the lights from and any pics on how it was done???
mods: CRG LS bar end, Avon Roadriders, EMGOs rejetted 132/42 2 shims, 19tooth sproket, Homemade ARK w/ UNI pod filters, stock guages removed and Veypor installed in it's place, Homemade FEK w/LED tail,brake, turn light bar.
Randy01 is offline   Reply With Quote
Old 10-23-2009, 04:32 PM   #3 (permalink)
I got the 3/4" light sockets and 1157 red LED lights at AutoZone. I also installed two white LEDs under the fender to light the license plate.
The light sockets are flared, so i trimmed the flare off using tin snips.
I ran two wires through a hole I drilled in the tube, just inside the battery box. the wires are of course protected so they don't chafe.
Tied the two (+) wire leads on the light socket together, and spliced to one of the the longer wires in the tubing.
I taped the ground wire to the outside of the socket and wrapped enough tape around the socket to fit tight in the tube.
Old 10-23-2009, 05:22 PM   #4 (permalink)
Favourite Bike: '07 Thruxton
hobbes80's Avatar
Other Motorcycle: None, ATM
It looks great... in VA, having the plate in front of the tire is illegal, so its not an option for me.
How do you feel about the brightness? I tried those 1157 LED bulbs as a replacement in my tail light and it was easily half the brightness as the regular bulb that is in there, even with the brake depressed. What about viewing angle from behind, can someone in a large SUV see your brake lights?
"...of course, he was the walrus. I could be the walrus, but I'd still need to bum rides off of people"
hobbes80 is offline   Reply With Quote
Old 10-23-2009, 10:06 PM   #5 (permalink)
I think they are certainly bright enough as the bulbs are not shielded by a lens cover. I'll have to get behind someone and ask them what it looks like. I am not sure about the plate location in Texas, I have been pulled over a lot and it hasn't been an issue...yet.
Old 10-28-2009, 06:02 PM   #6 (permalink)
how did you wire up the run/stop/turn signals? After market? or can all the wires just be run together? I love the idea, and it looks really damn good!
PhilipV88 is offline   Reply With Quote
Old 10-29-2009, 01:15 PM   #7 (permalink)
Randy01's Avatar
I think this is going to be my next mod. I found the lights at Autozone along with the sockets. The lights cost around $16.75 each and the sockets about $3.00 each. Not a terribly expensive mod considering the cost of a FEK.
This is one of those mods that might need a sticky!
Old 10-29-2009, 01:29 PM   #8 (permalink)
Favourite Bike: 2006 Thruxton
ageofoctain's Avatar
Great idea. Those look really good.
ageofoctain is offline   Reply With Quote
Old 10-29-2009, 02:14 PM   #9 (permalink)
I used the KURYAKYN Run-Turn-Brake Controller... post some pix when you get done.
http://www.kuryakyn.com/index.cfm/go...ID/39/IMID/732
Old 10-29-2009, 11:38 PM   #10 (permalink)
Favourite Bike: 04 Bonnie black
I use the 4710 also.They work great.
Running Tail Light not working, but Brake light does gittles17 Club Cafe' 8 04-27-2009 09:51 PM
LED tail light/brake light redden68 Classic, Vintage & Veteran 3 02-12-2009 07:56 PM
weird tail light/plate light problem ericherrin The Rocket Science Forum 1 10-23-2008 12:23 PM
What tail light with race tail? GNTurbo6 Triumph SuperSports 3 07-15-2008 01:25 AM
Integrated Tail light, brake light and turn signals?? stinger Sprint Forum 15 04-03-2007 10:21 PM
