Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 06-03-2005   #1 (permalink)
Since I often ride with my girlfriend I knew it was only a matter of time before I'd lose one of the plastic washers between the plastic and bolt for the rear seat cover. How many of you have done the same? Do you really think it serves any purpose? I guess this is the laziness in me, but I just don't feel like digging through the bins of washers @ Home Depot only to find they don't have what I need.
ThruxtonDave is offline   Reply With Quote
Old 06-03-2005   #2 (permalink)
Mancha's Avatar
I think it helps prevent direct pressure from the from the bolt from cracking the seat cover. I'm sure you can get by without it for a while, but I think it's a helpful thing to eventually replace. I'm sure Home Depot will have a teflon washer that would do the trick.
Ogle my bike here.
Mancha is offline   Reply With Quote
Old 06-03-2005   #3 (permalink)
Lost one too. Won't find a replacement at Home Depot.
But there are reasonable alternatives, teflon, rubber, plastic (although plastic substitute I used--which was thicker than original works fine). I got replacement because I was worried about pressure against cowl too.
puck is offline   Reply With Quote
Old 06-03-2005   #4 (permalink)
Favorite Bike: Thrux
Surferjo's Avatar
It will scratch the seat cowl if you don't replace it.
TRIUMPH-Turn an Ordinary Man into a Mechanic
Fun in Prague
Surferjo is online now   Reply With Quote
Old 06-03-2005   #5 (permalink)
I never got those, but fortunately I haven't used the cowl that much.
What's the ID/OD/thickness? Are they transparent or white? Seems almost silly to go to the dealer for such a small item.
joeswamp is offline   Reply With Quote
Lock-washer for seat bolt TB-T100 Twins Technical Talk 15 06-20-2007 12:04 PM
Rear axle bolt cover Towelie Sprint Forum 7 01-10-2007 07:25 PM
Cam cover bolt seals Strontje Twins Talk 7 05-21-2006 03:27 PM
cover bolt torquing - and question ryan Modifications & Workshop Talk 0 02-02-2006 08:51 AM
Broken valve cover bolt zimtok Modifications & Workshop Talk 2 12-06-2004 02:53 PM
