Club Cafe Cafe Racers; the Thruxton and other custom cafe-ed rides.
Old 05-02-2005   #1 (permalink)
So I bought some knee pads for my thrux at my local dealership, one sticks and one doesn't. I have tried extra adhesive but to no avail. Not sure what else to do...
Anyone had the same experience? If so how did you fix it? :???:
Kravr36 is offline   Reply With Quote
Old 05-02-2005   #2 (permalink)
You need to clean the tank of all wax, grease, etc, and apply in warm conditions. If the one has not stuck, there is probably some grease or wax on the surface--you might try cleaning the tank with denatured alcohol, then warm the pad with a hair dryer or heat gun and re-stick it. Most important thing is a clean surface and warm temperature.
So long, and thanks for all the fish!
DrEnglish is offline   Reply With Quote
Old 05-02-2005   #3 (permalink)
I had the same problem. Finally peeled them back off, took a heat gun (not a hair dryer, that didn't work!) wiped the sticky side with a rag soaked in a brake-clean solvent, cleaned the tank really well, then heated the glue side of the pad with the heat gun. When they were so hot I could hardly hold them, I stuck them in place. Been there ever since!
vikingdrvr
vikingdrvr is offline   Reply With Quote
Old 05-03-2005   #4 (permalink)
but then how do you get your knees on the pads :???:
mine are busy burning on the engine
dialysis is offline   Reply With Quote
Old 05-03-2005   #5 (permalink)
You're right, they should be called "just for looks" pads! I've thought about fabbing some more substantial heat shields about the size and shape of the 916 heel guards. Hmmm, a touch of carbon fiber maybe...nah.
vikingdrvr
Old 05-03-2005   #6 (permalink)
My knees grip the pads easily. What are you guys, like two inches tall?
Old 05-03-2005   #7 (permalink)
I first cleaned the tank with WD40, it works as a mild solvent for things like adhesive. I then washed the bike with a mild detergent and then I cleaned the tank with isapropyl alcohol. Once the tank was completely dry I stuck the knee pads on and then rolled it with a "J" roller. You can get a J roller at any home depot. This made sure that there were no air pockets under the pads. I also did this once the weather was a little warmer. Juan
Sunt Nobis Dracones Interficiendi
juan44 is offline   Reply With Quote
Old 05-03-2005   #8 (permalink)
You can buy a "J" roller at Home Depot? Wow, when I was a kid you had to go to a head shop for that...
Old 05-03-2005   #9 (permalink)
Old 05-03-2005   #10 (permalink)
:roflmoa2:
dr - you're too much!
kiwi is offline   Reply With Quote
patches on leather, what/how do you stick them down. sidortiz Gear & Gadgets 5 11-14-2007 09:26 PM
Tank Knee Pads TonyD Hinckley Classic Triples 15 10-06-2007 12:13 PM
Peal and stick weights... denman13 Biker Hang-Out 12 07-19-2007 01:15 AM
choosing a stick on tank protector sodapop Sprint Forum 28 04-16-2007 04:09 PM
Strap-on or Stick on? InfX708 Twins Talk 11 05-25-2006 02:38 PM
