You could try shooting some PB Blaster up there, too, although if the carb's not out then getting it to seep in will be difficult.
If I were you, I'd pull out the carbs, squirt some pb blaster in the hole, then let it sit overnight and try to remove the next day. The stuff works wonders when it's had time to sit.
2009 D675
2010 Duc Streetfighter S (sold)
2006 Thruxton (sold)
