Swapping a chain - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Ontario TourismSportbikeTrackGearNew BonnevilleMotorcycle.com
Old 12-23-2008, 08:29 PM   #1 (permalink)
Swapping a chain
Does the Thruxton have an endless chain? I took a quick look and didn't see a Masterlink.
amccullough is offline   Reply With Quote
Old 12-23-2008, 10:14 PM   #2 (permalink)
Hondo Cat's Avatar
Not sure about the Thruxton, but my Speedmaster has an endless chain.
Get action. Seize the moment. Man was never intended to become an oyster.
Theodore Roosevelt
2005 Triumph Speedmaster, D & D Chrome Megaphone Exhaust, Air Induction Removal, K & N Air Filter.
Hondo Cat is offline   Reply With Quote
Old 12-23-2008, 10:33 PM   #3 (permalink)
Favourite Bike: 06 Thruxton
roxythruxton's Avatar
Other Motorcycle: 76 CB750 86 Yammie SRX-6
They're an endless chain. I had to hack mine off to change it .
Long Live The Limey:D
BIR#220
Blue Knights Chapter XX
Green Knights Chapter 50
Yep. I've got some mods .
roxythruxton is offline   Reply With Quote
Old 12-23-2008, 11:50 PM   #4 (permalink)
Legend
Favourite Bike: 904cc Bonnie w/magwheels
sweatmachine's Avatar
the only way to remove the chain without cutting it off is to pull the wheel, shocks, swingarm etc...
my angle grinder with a cutoff wheel takes about, oh, 6 seconds to remove the chain...
Old 12-24-2008, 12:27 PM   #5 (permalink)
Thanks! Guess I'll pull out the grinder...
Old 12-24-2008, 12:41 PM   #6 (permalink)
Hondo Cat's Avatar
Remember you'll need a rivet tool for installation of your new chain for a strong chain. They're around $90.
Or, you can simply purchase a master link for $6 or $7 (which I did) it's alot cheaper. I haven't noticed any problems with the master link. Though some will caution against using it.
Theodore Roosevelt
Old 12-25-2008, 01:08 PM   #7 (permalink)
Favourite Bike: Thruxton
BillTheCat's Avatar
Yes I will (((Caution))).... If you ride aggressively.... you could loose a masterlink chain. I have and let me tell you it can be Dangerous !!!
New modern high torque high reeving motors can shuck a chain. It is cheep insurance to have it done or buy the tools to do it right yourself when putting on a new chain.
spend the bucks get chain & sprockets + tools and do it up right. After all if it keeps you up right it could save you a lot more than money.
LAND of the FREE ....*some restrictions apply. void where prohibited
BillTheCat is offline   Reply With Quote
Old 12-25-2008, 05:50 PM   #8 (permalink)
Thanks for the heads up. The EK chain I bought forever ago came with a clip-type Master Link. However, after reading the above posts I'm re-reading the directions and found this footnote:
"EK recommends using a riveted-type master link for all street and dual-sport motorcycles, and EK's clip-type as an alternative for off-road use."
But then it goes on to say: "Try using EK's patented screw-type master link, provides rivet-like fit and strength without special tools or removal of the rear wheel."
Does anyone have any experience or opinion on those?
swapping leads mlc Twins Technical Talk 4 07-20-2007 01:18 AM
injector swapping thejimrose Maintenance & Workshop Talk 2 05-05-2007 06:31 AM
Fairing Swapping GTLJR Sprint Forum 0 05-23-2006 09:52 PM
Parts swapping IamNeighbordave Hinckley Classic Triples 5 11-08-2005 05:56 PM
Swapping parts.... IamNeighbordave Maintenance & Workshop Talk 3 11-07-2005 10:43 AM
