Oil seeping down a head bolt and then coming out at the head gasket surface is not as remote as Jimmy Bush may think. I have been repairing Brit bikes for 39 years, and oil coming down the head bolts is common. Usually two things cause this: 1) The head has been milled considerably in the past. To the point that the original pushrod tube orings are actually now too thick and causing a certain amount of bowing of the head . 2) Cheap rocker box gaskets that do not have proper wire reinforcing. Watch out for wire reinforced gaskets that are thick, they are about as bad as non-reinforced gaskets. I always use thin wire reinforced gaskets, or solid copper rocker box gaskets, and coat both sides of the gaskets with Three Bond gasket sealer. This always works for me. I hate having to warranty oil leaks, but doing the rocker gaskets this way, I rarely, if ever, get a leaker these days.
