Amal Carb question - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-22-2008, 12:33 PM   #1 (permalink)
Amal Carb question
I just rebuilt a pair of amal 930 carbs on a 68 triumph engine and one of them is leaking out of the enricher button on the side of the carb. I think I need to replace the float needles, but I've never had a carb leak from something like that before.
pinhead is offline   Reply With Quote
Old 10-22-2008, 02:52 PM   #2 (permalink)
Favourite Bike: '64 Norton N15CS
McQueen's Avatar
Other Motorcycle: '79 Triumph T140D Bonnie
Extra Motorcycle: '71 Triumph T100R Daytona
Sounds like the float needle isn't seating. Or the plunger for the tickler isn't returning to the top of its travel. Push the tickler a couple times to make sure it returns to the top. Gently tap the side of the bowl with the handle of a screwdriver. See if it stops leaking. If not, drop the bowl and make sure the needle is in the float and the float is properly adjusted to the correct height.
+ Ton Up Club NorCal +
Nothing says "it's my first day on the Internet!" like putting a picture in your signature.
McQueen is offline   Reply With Quote
Old 10-22-2008, 05:55 PM   #3 (permalink)
I'll second McQueen, though I'd just add that if it's a sticking tickler, I've found it works best to push the button down, then slide your finger off so it snaps back up more forcefully. It's not a bad opportunity though, to check float heights. I've had to adjust it in every last bowl I've encountered, and I've done a lot of tinkering on AMALs in the past few months thanks to a deal I got on a big box 'o carb parts. They all seem to be set a bit too high, and it makes a substantial difference in terms of flooding and erratic engine speed to get them right.
--Scott
scottm is offline   Reply With Quote
Old 10-22-2008, 08:53 PM   #4 (permalink)
McQueen's Avatar
...nothing worse than a sticky tickler!
Old 10-23-2008, 06:30 PM   #5 (permalink)
Favourite Bike: 1979 Ducati 900SS
abmar's Avatar
Other Motorcycle: 1970 Triumph Bonneville
Extra Motorcycle: 1937 Ariel Red Hunter
Another common possibility is a leaky float. Shake it to see if it contains any fuel. Replacement is the only option.
abmar is offline   Reply With Quote
Amal carb question... fightingzero Classic, Vintage & Veteran 14 11-22-2009 07:33 AM
TR120R Amal Carb. HELP! FireTiger Classic, Vintage & Veteran 10 07-09-2009 07:50 PM
AMAL Carb : 689/205 Carb vs 376 series. 63Thunderbird Classic, Vintage & Veteran 3 07-08-2008 03:20 AM
Setting my Amal Carb quagmire Classic, Vintage & Veteran 3 04-10-2008 04:47 PM
76 T140- Amal Carb jetting question glw Classic, Vintage & Veteran 6 01-01-2008 07:19 PM
