71 Bonneville gear oil leak revisited??? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 10-20-2008, 10:26 AM   #1 (permalink)
Hi,
I posted a couple of weeks ago about a gear oil leak on my 71 Bonneville coming from a fitting on the forward side of the gear box inner cover and had no replies. I have narrowed it down to what I think may be the quadrant spindle. Does the spindle come through the inner gear box cover and is it held in by a carter (split) pin? I think that is what it must be. Has anyone had a gear oil leak from where that spindle comes through the cover, if so, is there a remedy?
Thanks for all replies.
10drum is offline   Reply With Quote
Gear oil leak on a 71 Bonneville??? 10drum Classic, Vintage & Veteran 12 09-20-2008 10:05 AM
Help with Tach Gear Oil Leak Jan_73_Bonne Classic, Vintage & Veteran 3 08-16-2008 04:09 PM
Sidestand bolt oil leak revisited Pinballer Daytona Deliberations 2 04-19-2008 04:02 PM
Oil leak at gear lever shaft TorqueyT Tiger Workshop (archive) 4 11-20-2005 05:22 PM
1973 Triumph Bonneville gear oil leak Classic, Vintage & Veteran 8 07-04-2005 04:46 AM
