rebuild questions - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-17-2008, 06:32 AM   #1 (permalink)
Favourite Bike: Mine
jseevers's Avatar
rebuild questions
I have a 1969 650 TR6R. I am rebuilding the top end and have a question on how to remove the cylinders. I have the head and everything else off and removed the 8 nuts on the studs that hold the cylinders on. Is there anything else holding them to the motor or should they just slide off now? I havent tried too hard to get them off yet I wanted to make sure everything was removed that needed to be. Anyone put on one of the 750cc big bore kits? Are they worth the money? That much more power over stock? Thanks for any input.
Jeremy
jseevers is offline   Reply With Quote
Old 10-17-2008, 07:23 AM   #2 (permalink)
TBS
Wedge a piece of rubber between the cam followers to stop them from dropping into the crankcase. There is nothing else holding the barrels, but if they are proving difficult to remove put a nut on a stud, then another on the top of it acting as a spacer, then unscrew the nut on the stud which will push the spacer nut into the lower fin and slowly the more you undo it the more the barrel will lift breaking the seal on the gasket,easy!!!
TBS is offline   Reply With Quote
Old 10-18-2008, 01:28 AM   #3 (permalink)
Favourite Bike: '07 Scrambler; grn/silver
1759AG's Avatar
Other Motorcycle: '69 TR6 Tiger
Extra Motorcycle: '74 T150V Trident
Has the motor been 'sitting' for a while or has it been used? Patience is virtue, if it has been sitting awhile; some PB Blaster or similar penatrant to loosen things up. Once all your bolts are off, should be good to go.
1759AG is offline   Reply With Quote
Old 10-18-2008, 04:47 AM   #4 (permalink)
jseevers's Avatar
That worked great!! popped right off the gasket. Thanks for the tip.
Starting first Triumph rebuild. Have a few questions. barnett25 Classic, Vintage & Veteran 14 05-05-2008 09:01 AM
When to rebuild? jonkull Classic, Vintage & Veteran 8 01-24-2008 04:40 PM
Chaincase Rebuild Questions (pics) hisnameisjimmy Classic, Vintage & Veteran 70 03-15-2007 12:14 PM
Rebuild in a can? jellero Sprint Forum 4 05-03-2006 07:02 PM
wanting to rebuild an engine so I've got some questions Classic, Vintage & Veteran 27 03-17-2005 04:13 PM
