Do you have a monoblock or a concentric carb fitted ?
If it's spitting out liquid then your needle valve is not working, there could be a number of reasons this is happening. The valve itself has had it, the float could be punctured, the distance piece (spindle bush) on the float bar could be missing ( monoblock carb only) float hight is set incorrectly or you could have crap in the float bowl not allowing the valve to shut off.
The slide only lets air through and a worn slide will let too much air get mixed with the fuel this results in a lean (weak) mixture which in turn makes for difficult starting.
HTH Mike
War has been the most successful of humanities cultural traditions
