Yep, spot on you hold the mag in the fully advanced position crank the engine to the correct setting using a degree disc, all depending on model, and then turn the points untill they just start to open and fit the drive gear to the end of the mag taper. Once drive gear is fitted turn engine back past ignition point then slowly turn engine back to ignition point and recheck points and timing degree.
Pre-unit T100 37º B.T.D.C
Pre-unit T110, TR6 35º B.T.D.C.
Pre-unit T120 39º B.T.D.C
On some 6T's and 5T's the ignition is set fully retarded.
Your timing will now be correct for high speed running, remember when starting just retard the ignition, once engine has started just push the lever untill it runs sweet. It takes a while but soon you will know when to adjust the timing as you ride along. It comes as natural as right foot gear change ! ! ! !
Mike
War has been the most successful of humanities cultural traditions
