To get the master cylinder off you will have to take the wheel out, undo the nut on the inner end of the brake lever shaft, pull the shaft out (easier said than done if it hasnt been greased). There will be a bang as the coil spring releases and the spring and its spacer will drop away. Then you can get at the nuts which hold the master cylinder to it's mounting plate, or remove the sleeve nut / bushing that supports the brake pedal spindle and remove the mounting plate from the bike with the master cylinder attached.
Various hydraulic pipes will have to be disconnected. Note that the rubber hose to the caliper mounting plate has a stripe printed along it's length, this is to enable you to check the pipe isn't twisted when it is re-assembled, and that the spacer (concentric with the coil spring) is assembled with the recessed side facing the brake pedal. You will need a hook of some sort to pull the coil spring into place when you re-assemble, a piece of welding rod would be a good starting point for making such a tool.
p.s. it's a Bonneville
