alternator rotor crank nut T140v - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com
Old 10-12-2008, 04:27 AM   #1 (permalink)
Favourite Bike: t140v
Other Motorcycle: motobecane mobymatic
hi
any clues as to how to lock engine in order to tighten crank nut on alternator side? i found it had worked loose and rotor was flapping around. lock washer used was star type not tab type as shown in manual. will replacewith the latter.
to hold engine the best i've managed is to put in gear and stand on back brake. fairly successful.
can i use tdc hole or is this verboten?
thanks in advance
KENT PLUMS is offline   Reply With Quote
Old 10-12-2008, 10:59 AM   #2 (permalink)
Favourite Bike: '67 Triumph Bonneville
Top gear with the foot brake.
You better have a close look at that rotor to make sure the outer casting with the magnet is still firmly adhered to the inner hub.
Clamp the hub in a vice with some washers on either side to shim up a gap between the outer rotor and the vice jaws, then try to slightly rotate the outer section with a pair of wide-jaw "channel-lock" pliers and see if you have any play. If so, you need to replace the rotor or it can fail with serious damage resulting to your primary and perhaps your left leg.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 10-13-2008, 06:37 AM   #3 (permalink)
sound advice as ever..thanks
Old 10-13-2008, 09:55 AM   #4 (permalink)
Favourite Bike: 72 Shovelhead
How to lock motor
Take a piece of rope, the soft stuff. remove sparkplugs, roll motor till pistons are down, stuff the rope in the plug hole, leaving part of rope hanging out of hole. Roll motor over till piston comes to a rest aginst said rope. Remove rope before starting might not be in the book, but I did'nt read it all........
Skunk is offline   Reply With Quote
Old 10-13-2008, 10:06 AM   #5 (permalink)
yeah, that method rings a bell from the distant past. i'll try the gradpaulz method first but if i cant get torque up to 40 lb/ft (haynes manual?) i'll get out the rope. cheers
T140V English_Spanner Classic, Vintage & Veteran 12 06-14-2010 03:43 PM
270 Crank vs 360 Crank - please explain NHScrambler Twins Talk 18 06-06-2006 05:42 PM
76 t140V Klicker Classic, Vintage & Veteran 4 05-18-2006 01:42 PM
2000 rs crank wounlt crank KidThunder650 Sprint Forum 3 04-15-2006 06:16 PM
T140V Klicker Classic, Vintage & Veteran 0 09-26-2005 05:46 PM
