Motorcycle.com
Old 04-10-2005   #1 (permalink)
i have a friend working on my transmission ( i won't mess with em ) he can't seem to get it to work right , but then again he doesn't really mess with 5 speeds often , he says he thinks the outer transmission cover is the wrong one , says it's for a four speed transmission and thats why it's not shifting right , think that could be it ? or is there not any difference between the 4 and 5 speed outter covers ? i'm building the bike so i've never ridden it or anything , if there is a difference in covers i don't know how i ended up with a 4 speed cover .
TheBondoBandit is offline   Reply With Quote
Old 04-10-2005   #2 (permalink)
The covers themselves are interchangable.
The plungers and the shifter shaft they ride in are not.
On my bikes, the 5 speed plungers measure 1.875" oal and the 4 sp 1.950".
The 5 speed shaft has a slightly different shape and stops against the cover with the plunger roughly 3/16" shy of center on the guide plate opening , the 4 speed will allow the plunger to go all the way to center.
Hope this helps. I spent 3 days and probably 25 dis and reassemblys before I finally figured it out....
oilyboot is offline   Reply With Quote
Old 04-10-2005   #3 (permalink)
awesome , so i just need a new 5 speed shifter assembly , you've been a huge help , thanks
Old 04-10-2005   #4 (permalink)
Gearboxes can be kinda tricky.
Can you run through all the gears shifting it manually (without the outer cover in place)?
Old 04-10-2005   #5 (permalink)
before i took it to my friend i could get neutral , first , and second , sometimes third , and then a bunch of fake shifts , i could also be in third and click all the way down to first in one click . i don't know what it's like now , he just says he's been messing with it all week and can't get it timed right because he thinks it's got a 4 speed cover on it . i'm just checking to see if thats a possibility and it would seem that it is
Old 04-10-2005   #6 (permalink)
If you can't shift through all gears in proper sequence without the outer cover in place, don't even bother installing it.
I'm not a Triumph expert by any means, but it sounds like the problem may be in the gearbox itself rather than the outer cover.
Old 04-10-2005   #7 (permalink)
yeah , i could go thru all the gears if i turned the cam plate by hand
Old 04-11-2005   #8 (permalink)
Is this a great forum or what? :gpst:
squod is offline   Reply With Quote
06 Transmission T100Tom Tiger Chat 11 08-06-2007 01:46 PM
GSG clutch cover and stator cover sliders! HiVel Speed Triple Forum 5 01-09-2007 10:04 PM
outer clutch basket play CharlestonRider Modifications & Workshop Talk 5 07-04-2005 10:23 AM
5 speed outer transmission cover TheBondoBandit Classic, Vintage & Veteran 2 04-21-2005 02:37 AM
outer pannier MilwFreddy Trophy 4 08-05-2004 12:27 PM
