» Log in
User Name Not a member yet?
Register Now!
Old 04-06-2005
Does a twin leading shoe brake unit from a late 60's Triumph fit an earlier wheel with a single leading shoe brake unit. Any info would be greatly appreciated.
Old 04-07-2005
Yes in certain cases, 8" or 7" but you need to understand that the surface which the shoes work on is wider on a TLS hub than a SLS.
The spokes on a TLS hub fit into a flange on the outside allowing the area inside the drum to be 33% wider than the SLS whos' spokes butt through the hub, INTO the inside of the drum.
The 1966 T120/TR6 has the TLS HUB but only the SLS brake plate with the wider shoes.
So if you have a flanged hub then the swop is easy. If you don't, then the shoes will be wider than the surface of the drum...................I hope I have described it, so you can understand.
Old 04-08-2005
Dagad, you are a wonderful resource. :gpst:
Old 04-09-2005
Crystal, Dagad :gpst:
Keep the Dream Alive
Brit Iron Rebels eight-0
Old 04-13-2005
Thanks guys, glad to help where ever I can. Roy
Old 04-13-2005
thanks DAGAD your explanation was a great help. Regards Coopers
What is the power delivery difference between a Vertical Twin and V Twin worldspeaker Triumph Twins HangOut 46 06-11-2007 02:28 AM
What is your favorite hooligan shoe/boot! TheGuvnor Speed Triple Forum 17 12-17-2006 09:34 PM
Cinema Triumphs in their leading roles.. bluesjeans Speed Triple Forum 18 10-09-2006 06:52 PM
A Shoe-in For Bike Of The Year Limey Speed Triple Forum 8 09-18-2006 09:24 AM
TWIN BRAKES ON ADVENTURER Regiz Hinckley Classic Triples 3 08-05-2005 09:44 AM
