73 TR7RV question - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 08-20-2008, 08:31 AM Thread Starter
Main Motorcycle: pre '68 Bonneville 750cc
Other Motorcycle: 86 Yamaha FJ1100
Extra Motorcycle: Custom mini-bike 165cc
73 TR7RV question
This is my first Triumph, and my first motorcycle in 20 years. I have a couple of easy questions. First, I need an exhaust fin and I measured it at 1-3/8. When I looked on-line they all seem to be 1-5/8. Does that sound right?? Can somebody point me to a good place on-line to get parts for the Triumph?? Also, what actually holds the exhuast into the head?? It looks like it just slids into the head and the two mounting bolts on the frame hold it in. I thought there would be a "doughnut" or something. It seems to have leaked a little exhuast on the outside of the exhuast pipe, it is a little black on the outside.
Thanks
TangoMike
tangomike is offline
post #2 of 8 (permalink) Old 08-20-2008, 12:46 PM
Main Motorcycle: 19?? BSA LightningBolt
Other Motorcycle: 1963 Triumph T100SS
Extra Motorcycle: 1973 Triumph TR7RV
Germ is offline
post #3 of 8 (permalink) Old 08-22-2008, 08:22 AM Thread Starter
Wow, thanks for the link. I am in the US, is there any issue with ordering from Canada?? Like customs. exchange rate or anything like that??
Also what actually keeps the muffler from sliding ot of the head?? The frame brackets only?? Or is there a nut or pin somewhere around the head that I am missing??
post #4 of 8 (permalink) Old 08-22-2008, 11:59 AM
Main Motorcycle: 1978 Triumph Bonneville
htown16's Avatar
The pipe is just a slide in fit. If its loose use some silicone sealer or make a shim out of thin metal. The brackets coming off the front of the engine are the only thing holding the pipes. Make sure they are tite. Ordering from Canada's no problem, they will handle the exchange rate, automatic if you use a credit card. However, if you want to order US try Klemps, Baxter's, Britich Only or MAP for a start.
Htown16, Houston, Texas
1978 T140E Bonneville, 1974 Trident, 1972 Commando, 1971 Commando
1974 Commando, 1970 BSA Thunderbolt, 2004 XL 1200R Sportster
Everything will be alright in the end.
If its not alright, its not the end.
htown16 is offline
post #5 of 8 (permalink) Old 08-22-2008, 12:08 PM
or Rabers
www.rabers.com
Ton Up NorCal
Germ is offline
post #6 of 8 (permalink) Old 08-22-2008, 12:20 PM
Or walk into any of the Triumph-British bike shops here in Portland. They usually have that stuff on the shelf.
Cafeparts is offline
post #7 of 8 (permalink) Old 08-23-2008, 12:31 AM Thread Starter
Thanks, the exhuast does have a good fit so that is the way it is suppose to be.
Thanks for the store tip. I just made an assumption they would not carry anything for a 73, just new stuff
TangoMike
post #8 of 8 (permalink) Old 09-07-2008, 04:35 PM Thread Starter
I went into Empire Clisec and they had the for 16.00 a pair. He looke at the one I brought and and asked what it was from. Apperantly not a Triumph.
Thanks
TangoMike
Overheating in very hot weather - 73 TR7RV jonkull Classic, Vintage & Veteran 35 05-30-2014 09:21 PM
Metal Fatigue - '73 TR7RV jonkull Classic, Vintage & Veteran 6 08-01-2008 04:05 PM
'73 TR7RV - Did I hurt my engine? jonkull Classic, Vintage & Veteran 9 06-12-2008 05:40 PM
Max RPMs for a 73 TR7RV jonkull Classic, Vintage & Veteran 2 03-03-2008 09:05 PM
I've Just Bought a 79 Tiger 750 (TR7RV) DavidGeorge Classic, Vintage & Veteran 2 06-24-2007 11:37 AM
