Did you test to see that the battery is actually charging? On most old bikes, the battery doesn't charge at idle. I don't know exactly about your Bonnie, but in general you need to have the motor up to running revs (on my old Honda above 3000 minimum, better at 4000) to see it charge. At that point a meter attached to your battery should show a 12v battery charging at 14+ volts. Someone will correct me here if it is significantly different for our old Brit bikes.
Also, is the battery properly maintained? If it is a regular battery, is the electrolyte up to level? Has it been sitting a long time without being charged? If the lytes are low, or it has sat and sulfated a long time without charging, it may not be holding a charge even if your bike's charging system is fine. If it is a glass mat battery, it also may not have tolerated a long sit without charging. I tossed one recently on my old Honda because I let it sit too long.
Mordechai Y. Scher
Santa Fe, NM
'76 Trident T160 (rebuilding)
'01 Sprint ST
'78 Honda CB750K
