AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBandit
Old 07-25-2008   #1 (permalink)
Favorite Bike: 1950 Indian Warrior TT
Other Motorcycle: 1973 Triumph Bonne
Extra Motorcycle: 1942 Royal Enfield CO
arghh, help with kickstart spring?
Well, I replace the shifter springs, then went to put the gearbox outer cover back on, well I wound the kick start spring too much and messed up the kickstart spring real bad, so I have another coming, is there any stratightforward way of putting the cover back on correctly in regards to the kickstarter? Basically, once I have the new spring, what should i effectively do to re-install correctly?
thanks for any advice
Jan_73_Bonne is offline   Reply With Quote
Old 07-25-2008   #2 (permalink)
Favorite Bike: BMW K1200LT
Woolly's Avatar
Other Motorcycle: Ducati ST2
Count your fingers before you start, and if you've got roughly the same number when you finish, you've done a good job
Seriously though, check that the teeth on the kickstart pinion & ratchet are good - sharp to the point of being painful, check the teeth on the quadrant - the first is intentionally worn away, but the rest should mesh perfectly with the ratchet pinion. The only purpose of the spring is to support the kickstart lever in the 'up' position - don't wind it up too tightly. Whilst you've got the gearbox outer cover off, take time to check the gear change quadrant return springs - they often fail, leaving you with a droopy pedal
BMW LT - 16 countries, 2 CONTINENTS & counting
Mercedes Benz SLK 350 Andradite Green (6 speed manual] Vauxhaul Vectra 2.0 SXi
Ducati ST2
1974 Triumph Bonneville 750 T140V
MY VIDEOS
Woolly is offline   Reply With Quote
Old 07-25-2008   #3 (permalink)
the case
it's putting the external case on and setting where the kick start should be that is the real major problem
Old 07-25-2008   #4 (permalink)
Favorite Bike: 77 Bonneville
OzBloke's Avatar
Jan73,
If you wind the kickstart pedal approx 1.75 turns counterclockwise (when facing the outside of the cover) winding up or tightening the spring, then hold the cover with the pedal at the 9 o'clock position, then slide the cover on. When you get it seated, releasing the pedal slowly will see it stop at the 11 o'clock position if everything is aligned properly.
If you have the pedal off the shaft, use an 8" or 10" shifter on the flat section of the shaft, and use the flat as the 9 o'clock / 11 o'clock reference.
Hope this helps
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 07-26-2008   #5 (permalink)
winding the pedal, question to OzBloke
If I wind the pedal 1.75 turns, then the shifter would be at 3 o'clock assuming the pedal started st the 12 oclock position??, then how do I get it at 9 when putting the cover on, that would be 1.25 turns, sorry for the dumb question, my first time working on a bike
Old 07-26-2008   #6 (permalink)
Favorite Bike: 63 T120C Hardtail Rat
wingnut's Avatar
Other Motorcycle: 74 Bonneville 750 Basket
on the inner cover there is the hole that the kicker spindle seats in, just left of that is the stop for the kicker cam, the teeth should be towards the bottom of the bike., this half-moon shape provides for stop in both directions.
refer to your manual on the correct position of the spring on the spindle, or i can upload a scan of it on Monday for you.
i don't recall how any turns it took, just enough to put tension, it wasn't wound up too tight so there wasn't much of a struggle, and it is still sufficient to return the arm with no problem, i think winding it too tight puts some stress on the inner cover. hope this helps.
oh and make sure you are winding this anti-clockwise (counter-clockwise) when the outside cover is facing you
Too wierd to live, too rare to die.
My Bikes
My Page
wingnut is offline   Reply With Quote
Old 07-26-2008   #7 (permalink)
OzBloke's Avatar
As Wingnut mentions, you need to note where the centre of the spring mounts on the kickstart quadrant. After attaching the spring (inner to quadrant, outer to pin on the case, it will require about .5 turn to get it to the position where the quadrant is pointed towards the 5-6 o'clock position. Then you take it 1.25 turns anti-clockwise from there. You may need to push the kickstart shaft in a bit to get the quadrant over the stop "pin/shaft", and this is why it's easier to take the pedal off the shaft and use a shifter.
Per Ardua Ad Astra
Kickstart spring replace/right footpeg removal spearce72 Classic, Vintage & Veteran 8 06-11-2008 04:54 PM
Kickstart gjohnsonvp Twins Talk 19 09-26-2007 07:40 PM
Kickstart Spring jonkull Classic, Vintage & Veteran 9 08-16-2007 11:52 PM
kickstart watch spring unsprung johnnypence Classic, Vintage & Veteran 9 05-08-2006 12:10 PM
Kickstart woes nootheridleft Classic, Vintage & Veteran 3 03-02-2005 03:28 PM
