Old 07-15-2008   #1 (permalink)
Newbie
ignition timing on 62 bonnevill
I have an "original" -62 bonnie pre-unit with Lucas Rita el.ignition. What is the best way to adjust the ignition ? I have no strobo.lamp, but I can probably get one if it is necessary.
Thanks!
Bjorn
nortri is offline   Reply With Quote
Old 07-15-2008   #2 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
You'll need to install a degree wheel to time it accurately, but you can always use the old "stick in the hole" method to get close enough to start the engine, then time it closer by ear and monitor your plug condition to fine-tune.
1. Check your book for the length of the stroke
2. Divide that figure by 180 (NOT 360)
3. Multiply the result by "X" (degrees BTDC for timing), write down that length, somewhere between 1/4 - 1/2" I would GUESS
4. Get a thin rod or screwdriver and stick it in the Right cylinder at TDC on the compression stroke (both valves closed)
5. Make a mark on the rod right where it touches the edge of the spark plug hole
6. Make a second mark on the rod the distance as calculated in step 3
7. Rotate the engine through another cycle and as you are 1/4 turn from approaching TDC again, insert the rod back in the hole
8. SLOWLY rotate until the second mark aligns with the top of the spark plug hole. You will be VERY close.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
GrandPaulZ is online now   Reply With Quote
ignition timing on 62 bonneville nortri Twins Technical Talk 1 07-15-2008 11:42 AM
Ignition Timing on 865 Deacon Twins Technical Talk 2 03-13-2008 09:39 AM
TT600 ignition timing OzTT Triumph SuperSports 4 05-29-2007 11:16 PM
Ignition timing musicman59 Classic, Vintage & Veteran 6 09-07-2005 09:10 AM
Tiger 90 Ignition timing gazpacho Classic, Vintage & Veteran 8 10-12-2004 03:58 PM
