Michael, the cam timing will PROBABLY be at one of the keyways BUT.... it could be a tooth either way depending on the setting for that cam. What I would suggest is, set the degree disc on the crankshaft (as per Lutz) at TDC and then locate the intermediate wheel on the keyway adjacent to the timing mark, do this for the inlet first.
Set the valve lash at 0.020" and read out what the figures are when the lash gap has JUST closed up. You want firures in degrees, inlet opens (34) before TDC. Inlet closes (55) after bottom dead centre, when the lash JUST reappears. Repeat for exhaust but you are looking for exhaust opens (55), exhaust closes (34).
Roy.
