Clutch cable routing??? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-11-2008, 03:02 AM   #1 (permalink)
Favourite Bike: '07 Scrambler; grn/silver
1759AG's Avatar
Other Motorcycle: '69 TR6 Tiger
Extra Motorcycle: '74 T150V Trident
How much heat can the clutch cable sleeve take?
I have a set of "high pipes" for my '69 TR6; it is routed very close to the clutch cable (boot area where connected to casing). They have been used on a Truimph before, but I have seen melted cable sleeves too.
Any suggestions on a possible "remedy" to prevent melting; not sure how much 'bend' is adviseable to route the cable away from the area?
Thanks,
Bryan
1759AG is offline   Reply With Quote
Old 07-11-2008, 03:46 AM   #2 (permalink)
TBS
I just use a loose cable tie around the rear rocker oil feed pipe and route the cable under the front tank rubber, this should keep it well clear of the pipes.
TBS is offline   Reply With Quote
Old 07-11-2008, 01:38 PM   #3 (permalink)
1759AG's Avatar
TBS,
Thanks. I've been looking at photos of other bikes; not sure if they are riders or displays. The pipe is REAL close to the boot that comes out of the case. Hopefully with the 'mounting bracket' I will be able to direct the pipe one way or the other for clearance. Didn't know if I could possibly wrapp the cable with some heat material???
Old 07-11-2008, 02:06 PM   #4 (permalink)
Favourite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1999 Yamaha Virago 1100
I always routed mine down the left side (sitting on bike) of the steering head and between the frame tubes. It will come out behind the r.h. petcock. Needless to say, make the bends as wide and smooth as possible. Mine's been fine for years, and I did the same on my old '70 TR6C model. No problem with high pipes.
Hope this helps: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 07-11-2008, 04:35 PM   #5 (permalink)
1759AG's Avatar
Thanks Jim,
We'll see what happens! Appreciate the time and effort.
Anyone have pics of the clutch cable routing by the rad? Iggy762 Sprint Forum 0 09-17-2006 05:20 PM
clutch cable routing? roadkill Speed Triple Forum 8 03-10-2006 09:25 AM
Clutch and Throttle Cable Routing dcorbell Speed Triple Forum 1 02-10-2006 04:55 PM
02 RS clutch cable routing rkjjeep Sprint Forum 7 02-19-2005 04:45 PM
Clutch cable routing speed four green Triumph SuperSports 1 04-29-2004 05:34 PM
