Common for the tank tube to crack there. When you weld it, fab up some gussets to reinforce the pivot tube, spread the load. To confirm the location of the leak, put some oil based dye in the primary case and run it. If you get colored oil, then suspect the gasket behind the cover plate or a loose plate screw or a worn spot from the chain.
