"Way back when" I owned a '66 TR6R, it had a hose from the filler neck of the oil tank that went to a clip on the chainguard to do just that...lube the chain. Inside the neck was a small valve tapped into the oil return pipe, with a screw adjustment to regulate the oil flow; does yours have this? It's possible that the earlier ones didn't have it and it was discovered that too much oil was flowing on the chain, the road, the rear tire, etc. Most of us used to just shut the valve off as achieving the proper adjustment was pretty hard (the faster you go, the more oil is returned to the tank,,,you get the picture), and using a good chain lube was always a better idea, at least in the thinking of that day.
Your history lesson for today...brought to you by the "village idiot": Jim
Jim Ballard
