| Classic, Vintage & Veteran For Coventry and Meriden Models. Anything pre-Hinckley goes. |
07-08-2008, 03:35 AM
sputtering problem
76 t140 bonneville with 7600kms on it,,,developed a sputtering miss on a road trip ,,got her home,,,replaced the coils ,,,still the odd sput ,,,replaced the points condensers and wires still sputtering ,,mostly when accelerating ,,but now seems to do it at idle and crusing speeds,,i,m suspecting a shorting wire to the points,,anyone come across this problem?
07-08-2008, 06:55 AM
Formula Extreme Favourite Bike: 77 Bonneville
What do your plugs look like? Have you replaced them as well?
When you say you replaced wires - which ones?
Have you checked the bullet connectors under the tank that connect the points wires to the loom towards the coils?
Might be worth checking the wires (Black/Yellow & Black/white) going to the points, where they pass through the rear of the timing case into the points well - check for wear on the wire coverings and shorting to frame. Also check the connectors around the points, and for "deposits" and shorting around the points pillar.
Hope this helps.
Per Ardua Ad Astra
07-08-2008, 11:42 AM
sputtering bonneville
the plugs were new a week ago,,,noticed the left one is black,,,so i assume thats the one thats been missfiring ,,i was thniking it could be where the wires pass thru the case going to the points,,,not sure if there are connectors under the gastank ,,all connectors under the seat to the coils are tight ,,is there connectors in the taped up wiring under the tank ?,,,also i see one of the connectors at the points is missing the one tang that goes over the points spring,,i tryed to make sure the one tag left was touching the spring,,,for a connection,,,,was going to replace it,,,but i havent any connectors like that ,,,,
07-08-2008, 11:45 AM
wires
sorry oz bloke ,,,when i mentioned replacing wires i was refuring to the spark plug wires even though the old one,s checked out fine with a ohm meter 1 ohm resistance ,,,the new one,s measured 2 ohms
07-08-2008, 11:49 AM
Site Supporter SOTP Vintage Series Favourite Bike: '67 Triumph Bonneville
Posts: 7,674 Other Motorcycle: British Iron Extra Motorcycle: Dreer Norton Prototype
Service and charge your battery, then test it with a battery tester. Sounds like battery issues to me.
Then again, it could be ANYTHING; long distance troubleshooting is no fun.
07-08-2008, 05:37 PM
YOu could be getting too much fuel in the cylinder with excessive carbon. I had a sputter issue, and it was a flooding carb, and nothing to do with ignition! Just another thing to check (After I had replaced plugs and wires)
Andy
1970 Tiger 650 TR6R (bone stock)
And past bikes:
2004 Speedmaster
1996 Thunderbird
07-08-2008, 06:11 PM
World SuperBike Favourite Bike: 2002 Triumph Trophy
Posts: 2,040 Other Motorcycle: 1970 Triumph Tiger 650 Extra Motorcycle: 1999 Yamaha Virago 1100
Silly question, but.............are you sure that the chokes are fully pulled off??
I've a long story to tell about that: Jim
Jim Ballard
07-14-2008, 07:08 AM
hey guys tks for all the suggestions,,,took the bike out yesterday problem still persists,,,got fed up with the problem and sold the bike,,,lol,,,,kidding ,,,was about to start to open up the carbs to check em,,,removed the gastank to access and to check the wiring ,,,,low and behold ,,on of the bullet connectors was half unpluged ,,cleaned and replugged it,,,reinstalled the gastank and took it out for a test drive,,volia problem solved,,running like a top again,,,duhhhhhhhh,,,i guess i,ll chock this one up in my learning curve ,,and put it in the memory bank,,,tks for all the suggestions,,,
07-14-2008, 08:20 PM
SuperSport Favourite Bike: 1970 TR6 Spring Gold!
Nice to hear another problem solved.
By the way, I've seen stranger things around here. Nothing suprises me about these bikes. They keep you on your toes.
Hey, What's this oil on the floor?
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
06' Sputtering
nunzo |
Sprint Forum |
4 |
11-13-2006 11:20 PM |
Sputtering
kan4132 |
Twins Technical Talk |
4 |
09-06-2006 11:50 AM |
sputtering
Maintenance & Workshop Talk |
9 |
08-10-2004 07:55 PM |
Sputtering?????
Sprint Forum |
4 |
08-09-2004 10:04 PM |
sputtering adventurer
trigger1769 |
Hinckley Classic Triples |
4 |
04-15-2004 03:27 PM |
