OIF Oil Reservoir Flush - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearHonda Powersports Ontario Tourism
Old 07-07-2008, 10:20 PM   #1 (permalink)
Favourite Bike: 1976 Bonneville T140V
Question OIF Oil Reservoir Flush
Alright, I've searched through the forums for any threads regarding a flushing procedure for an OIF Bonneville and can't find anything about fluhing the reservoir.
The shop manual says that it is "advisable to flush out the oil reservoir with a flushing oil or if this is unavailable use kerosene"
Do you guys flush the reservoir at every oil change? If so, what do you use and how do you go about it? Any info is greatly appreciated.
I wanted to ask before I just started pouring kerosene through the oil fill cap on the frame.
This a 1976 Bonneville T140V.
Thanks
Scott
spearce72 is offline   Reply With Quote
Old 07-07-2008, 10:57 PM   #2 (permalink)
Favourite Bike: '70 T100R
Other Motorcycle: '79 T140E
reservoir flush
well, here I go again, talking thru my hat, but I just did this a couple days ago, and here's what I found. The aluminum bottom of the backbone, and the strainer should be removed and cleaned in kero, and the strainer should be maybe sprayed with carb cleaner too. Blow it dry with compressed air and see that the gunk is gone. The bottom inch or two of my reservoir was just rough as a cob with weld splatter, and I am amazed that they let that get thru QA, lol. I tried wiping with a paper towel, and left more crap in there than i removed, so carb spray and picking the lint out was what was called for. I think if you used carb spray on the bottom inch or two of the reservoir inside, you would be doing all you can. Use paper gaskets, purchased or cut out of resin paper, with grease or a light coat of permatex, both sides of the strainer flange, and in my case the strainer flange was rusty, so I wire-wheeled the crap out of it, then reassemble. Don't know what else you can do. Pouring kero down the pipe won't do much, it seems to me. Good luck and good riding. Oh, yeah, be sure to scrape the flange on the bottom of the backbone to get the old gasket crap off, and do a good job of it.
pogue54 is offline   Reply With Quote
Old 07-08-2008, 12:12 AM   #3 (permalink)
Favourite Bike: 77 Bonneville
OzBloke's Avatar
Thumbs up
Good response, Pogue !
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 07-08-2008, 09:15 AM   #4 (permalink)
Thanks for clearing that up Pogue.
Old 07-08-2008, 11:04 AM   #5 (permalink)
htown16's Avatar
You might consider fitting an external oil filter. Once I did that I never take the sump plate off.
Htown16, Houston, Texas
1978 T140E Bonneville, 2004 XL 1200R Sportster, 1972 Commando,
1974 Commando
Everything will be alright in the end.
If its not alright, its not the end.
htown16 is offline   Reply With Quote
Old 07-08-2008, 02:25 PM   #6 (permalink)
htown, I actually ordered an external filter from MAP yesterday and it should be here in a day or so. I was hoping the external filter would keep me from having to drop the plate in the future, but MAP said I would still need to still take of the plate for oil changes even with the external filter hooked up.
So, it sounds like you've had good results with just changing the external filter and leaving the plate alone.
I think once I get the reservoir cleaned, oil changed and the new MAP filter installed, I will skip the plate next oil change. Maybe just do it every other oil change in the future.
Again, thanks for the comments.
First Oil Flush Stoogsy Twins Technical Talk 28 04-02-2008 10:53 AM
Flush Gas Cap Jhtjon Twins Technical Talk 5 08-17-2007 11:48 AM
FLUSH RADIATOR 2002SPEEDTRIPLE Speed Triple Forum 18 02-09-2007 12:56 PM
Flush fit gas cap 127mph Club Cafe' 3 07-05-2006 12:23 PM
radiator flush tnsen Hinckley Classic Triples 10 10-10-2005 10:24 AM
