Leaky float valve - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!New BonnevilleMotorcycle.com
Old 07-07-2008, 01:05 AM   #1 (permalink)
Leaky float valve
I'm about to go insane. I read a tech bulletin that the float bowl needs to be heated with a torch and the float valve seat tapped upward. Anyone ever try this? It might work for a new one. My seat ain't going anywhere. I also read to punch the hinge supports. It helped for a few miles. I have a new needle valve (rubber-tipped) and a non-leaking float. I keep getting the drips, and don't know what to do
It's ironic that I have a motor that I was able to cure all the oil leaks.
Andy
1970 Tiger 650 TR6R (bone stock)
And past bikes:
2004 Speedmaster
1996 Thunderbird
ajslug is offline   Reply With Quote
Old 07-07-2008, 09:51 AM   #2 (permalink)
Favourite Bike: '67 Triumph Bonneville
Clean and dry everything, then re-assemble and stand at the ready with a spray can of Arrid extra-dry deodorant spray.
Spray the carb with the can, then turn on the petrol tap. Turn the tap off as soon as you see the slightest moisture appear.
THAT is the area to work on first. I'll bet nickles to nuts (I can't afford dollars and doughnuts) that it's a worn out fiber washer or bowl gasket that won't seal right till you rework the mating faces back to square and flush.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 07-07-2008, 10:15 AM   #3 (permalink)
float valve
Probably dont have anything to do with your problem, but, the old XS650 yamahas with Kehin carbs had a screw in needle valve seat, ther was a little known o ring on the seat. it would get hard with age and leak. didnt need to get a new one, just replave the tiny o ring. there was a little bracket with a screw that held the seat in.
cliff
2006 Bonnie Black
1980 Yamaha xs650 sold 4-30-2011
alfacliff is offline   Reply With Quote
Old 07-07-2008, 12:07 PM   #4 (permalink)
htown16's Avatar
I assume you are trying to adjust the float level. Top of float should be .080" below front edge of bowl when pushing down on plastic tangs not needle. Don't use a torch. Dunk the bowl in boiling water or use a hair dryer and use a brass rod as a drift. Have you checked to see if the top of the float bowl is flat. Use a piece of sand paper glued to a piece of glass and knock off any irregularities. Also the banjo fitting at the base may need a new gasket.
Htown16, Houston, Texas
1978 T140E Bonneville, 2004 XL 1200R Sportster, 1972 Commando,
1974 Commando
Everything will be alright in the end.
If its not alright, its not the end.
htown16 is offline   Reply With Quote
Old 07-07-2008, 11:08 PM   #5 (permalink)
thanks for your replies. The gaskets are not leaking (bowl or banjo) They were replaced too. The leak is coming from the air cleaner.(vent tube into air cleaner) I think the seat is pitted/worn out. I will try to polish it with a q-tip, some polish, and a drill. Has anyone successfully moved the seat? It's eaiser said than done.
Andy
And past bikes:
2004 Speedmaster
1996 Thunderbird
Old 07-07-2008, 11:13 PM   #6 (permalink)
cliff
Thanks, but the seat is hard-pressed into the float bowl. No screws. No o-rings.
Andy
And past bikes:
2004 Speedmaster
1996 Thunderbird
Leaky fuel cap Aurelius Speed Triple Forum 2 12-04-2007 05:16 PM
Leaky gas valve on T100 HiVel Twins Talk 3 03-18-2006 12:36 PM
Leaky valve cover gasket backspinnn Sprint Forum 2 11-11-2005 05:28 AM
Leaky Beast meatwagon Twins Talk 22 09-03-2005 06:49 PM
Leaky engine bigD Tiger Workshop (archive) 10 06-07-2005 02:18 PM
