Clutch disassembly TR5T - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-06-2008, 11:57 PM   #1 (permalink)
Favourite Bike: 1973 Bonneville
I'm helping a friend of mine work on his 74 Trophy Trail. We are almost ready to reassemble the clutch after taking care of a kickstart problem, but the basket and center are still together. Do we need to separate these in order to replace the roller bearings? If so, how is it done? As far as I can tell, there is no Haynes manual that covers this model, though I suspect the procedure is probably the same as that for a 1973 500. The workshop manual doesn't really describe how to separate the basket and center or replace the bearings, so we're a bit stuck.
Bonnevillain is offline   Reply With Quote
Old 07-07-2008, 03:26 AM   #2 (permalink)
DAGAD's Avatar
Check the thread '78 Tiger clutch question' should help?
Roy.
Old 07-07-2008, 09:48 AM   #3 (permalink)
Favourite Bike: '67 Triumph Bonneville
Use a bigger pry bar.
I don't think there is anything to keep those two apart.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Need help with fork disassembly rminchi Twins Technical Talk 11 03-26-2008 09:45 PM
Disassembly of F3 Forks? Hawk Twins Talk 6 10-14-2005 10:39 AM
SSSA disassembly question bridgestone175 Sprint Forum 7 08-19-2005 12:15 PM
'74 tr5t Maintenance & Workshop Talk 2 06-03-2005 04:59 PM
Mre TR5T Questions Will Classic, Vintage & Veteran 4 04-25-2004 09:08 PM
