wobbly clutch basket - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-06-2008, 09:28 AM   #1 (permalink)
I just installed a new clutch basket in my 1960 bonne.
I put about 60 miles on it and it ran great. Went to check the primary chain freeplay and noticed the clutch basket was moving. I took the primary cover off to see what was up. I pulled on the basket and it moves in and out about a 1/16 inch maybe more. I also noticed that the chain rivits cut into the thin metal ring around the outside of the basket, but only on about 6 inches of the circumference. I took off the primary chain and kicked it over and the basket wobbles. I thought maybe the new basket was defective cause it wasn't straight to start with, so I put the old basket back on and kicked it over. Same thing, it wobbles. To get the back primary cover off I broke the hub that the basket's rubber splines on to. I used a home made puller. It snapped a piece of the back of the hub off so I welded an old socket to the hub with a nut welded to the top and put in a bolt and the hub came right out. Guess I should have bought the tool!! Turns out a new hub isn't available so my parts guy found me a used one. I didn't buy new bearing balls for the basket. Is the transmission shaft bent? Are the ball bearings bad? I also noticed that the basket cut a very fine line on the inside of the primary cover. The transmission seal doesn't leak. Should I just keep on riding this way or will there be a catastrophe?
davetile is offline   Reply With Quote
Old 07-06-2008, 11:17 AM   #2 (permalink)
Favourite Bike: '67 Triumph Bonneville
Sounds like the shaft is bent.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 07-07-2008, 04:38 PM   #3 (permalink)
Favourite Bike: 1956 Triumph TR6 Trophy
how about the bearings?
michaels90na is offline   Reply With Quote
wobbly clutch basket davetile Twins Technical Talk 1 07-05-2008 11:45 PM
wobbly clutch basket davetile Classic, Vintage & Veteran 1 06-26-2008 05:38 PM
wobbly clutch basket davetile Classic, Vintage & Veteran 0 06-23-2008 10:07 PM
Clutch basket removal 666Bonneville Classic, Vintage & Veteran 6 06-09-2008 04:35 PM
outer clutch basket play CharlestonRider Maintenance & Workshop Talk 5 07-04-2005 11:23 AM
