Oil pressure ?'s '70T100C - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
New BonnevilleOntario TourismSportbikeTrackGear
Old 07-05-2008, 11:30 PM   #1 (permalink)
Favourite Bike: 2004 BMW R1150 RS
Ahobie17's Avatar
Other Motorcycle: 1970 Triumph T100C
Extra Motorcycle: 1984 BMW R 80 G/S
Question Oil pressure ?'s '70T100C
I have a couple of ?'s concerning the oil pressure on a 1970 T100C, I have a new oil pressure light and when cold the light stays off even at a fast idle, 1,200 rpms, but when hot the light comes on dimly at 3,400 rmps and gets brighter at lower rpms. The engine is newly rebuilt but the oil pump wasn't replace (low mile engine). I'm running Mobile synthetic 20w50. Is this normal behavior? Should I replace the oil pump if so will the check balls need to be seated or will this already be done? What about a high volume oil pump as I seem to recall seeing that one is offered somewhere (if you know where tell me)?
Thanks
Ahobie17 is offline   Reply With Quote
Old 07-06-2008, 01:19 PM   #2 (permalink)
htown16's Avatar
This is not normal behavior and you should not ride the bike until you correct it. First possibility is that the oil light is bad. Replace the sender with a guage and see what the pressures really are at idle, and mid rpm, cold and hot. Since the motor has recently been rebuilt a prime suspect is the crank seal on the timing side. There have been a lot of reports of early failure of the seals due to inverting. A lot of people recommend replacement with the Pioneer brand. I believe Mitch Klemp carries them. The pumps them selves rarely fail since they run in oil.
Good luck
Htown
Htown16, Houston, Texas
1978 T140E Bonneville, 2004 XL 1200R Sportster, 1972 Commando,
1974 Commando
Everything will be alright in the end.
If its not alright, its not the end.
htown16 is offline   Reply With Quote
Old 07-06-2008, 09:42 PM   #3 (permalink)
Ahobie17's Avatar
Where can I find an oil gauge that fits??
Old 07-06-2008, 11:59 PM   #4 (permalink)
htown16's Avatar
A cheap automotive oil pressure gauge will work. Remove the sending unit for the light and fit the gauge. I'm not sure what the thread size is for a 500. Anyone else out there know?
1974 Commando
Old 07-07-2008, 09:10 AM   #5 (permalink)
Ahobie17's Avatar
I have a SW gauge, but finding the right fittings, might prove difficult.
Thanks
Old 07-07-2008, 12:19 PM   #6 (permalink)
htown16's Avatar
The fitting on a 1970 650 would be a 1/8 " 27 tpi straight pipe thread. I'm guessing the 500 has the same. It only needs to be seated lightly, to avoid cracking timing cover.
You could skip the gauge step and just pull the timing cover and check the seal because that would be the next step. Only tricky bit is retiming engine. Have you checked to see if oil lines are attached correctly and are not blocked. The oil light only comes when the pressure drops to about 5 psi. This definitely not what you want at 3500 rpm.
Good Luck
Htown
1974 Commando
Old 07-07-2008, 01:28 PM   #7 (permalink)
Ahobie17's Avatar
I found some fittings and it'll be good to know what it is exactly, threads are 1/8x27 as you said. Just light seepage at the points, but are you referring to the triangular cover for the seal?? I suppose you are.
Re-timing the motor doesn't other me, as much as resetting the timing, neither is that bad though.
Old 07-07-2008, 07:29 PM   #8 (permalink)
htown16's Avatar
Yes, the triangular cover. On the crank seal the clip should be on the side away from the crankcase and on the points seal toward the crankcase. It'll also give you a chance to check oil pump.
1974 Commando
Old 07-08-2008, 08:45 PM   #9 (permalink)
Ahobie17's Avatar
Exclamation
I connected the oil gauge and the pressure was low, sub 20psi, I do get a steady stream out of the line, then I removed the oil tank cap and was getting a steady stream of oil there too. Guess I'll be looking behind the timing cover, what signs am I looking for if the seal is bad? I highly doubt it is, but what do I look for?
Thanks
Old 07-08-2008, 09:20 PM   #10 (permalink)
htown16's Avatar
Suggest you go over to the Triumph section on Britbike Forum and do a search on seals or low oil pressure. Lots of posts on there describing the problem.
1974 Commando
Oil pressure gone!!! TThruxton Twins Technical Talk 5 10-02-2007 11:52 AM
ti/yre pressure WhoWantsTrident T3 Sport / Touring Forum 8 06-06-2007 04:29 PM
air pressure maryost Twins Technical Talk 8 03-26-2007 11:18 AM
oil pressure okiecityflash Classic, Vintage & Veteran 13 03-29-2006 02:15 AM
Low Oil Pressure dtronz Triumph SuperSports 11 09-03-2005 01:43 PM
