TR6 dies from no gas, but there was still gas in tank - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-05-2008, 07:47 PM   #1 (permalink)
Favourite Bike: my 1969 TR6C
I was riding home today & the bike felt like it was wanting to die at a couple traffic lights. I thought it was getting close to needing to flip on the left reserver petcock & when it did die on a downhill, I flipped the reserve on, but about 200yds later it died again. I opened the tank & there was still a tiny amount of gas in there that I could hear swishing around. Wouldn't it have run dry before cutting out & how come the reserve didn't work at all? Anyway, AAA happened to drive by, filled me up & it started again. I don't quite get why that gas was still in there & it cut out.
clamp007 is offline   Reply With Quote
Old 07-05-2008, 07:53 PM   #2 (permalink)
Favourite Bike: 63 T120C Hardtail Rat
wingnut's Avatar
Other Motorcycle: 74 Bonneville 750
hmm, you said you were going downhill;
i guess depending on the style tank you have this would matter.
like i have a 70's bonnie tank and if i was going downhill for too long the gas would be at the front of the tank
or it could be something completely different
Too wierd to live, too rare to die.
My Bikes
wingnut is offline   Reply With Quote
Old 07-05-2008, 08:02 PM   #3 (permalink)
Favourite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1999 Yamaha Virago 1100
For what it's worth, I had the same thing happen to me on the '70, many years ago. Flipped on the reserve and "nothing". I've run it down there a couple of times since and it's been fine. Might be a good idea to just run it on reserve once in a while to clean out the line. If you can, pull the reserve side line and make sure that fuel flows.
Just the mindless advice of the "village idiot" again: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 07-05-2008, 09:28 PM   #4 (permalink)
Favourite Bike: 77 Bonneville
OzBloke's Avatar
Clamp 07,
Good responses from Wingnut and Jim (who is definitely NOT a village idiot, despite his assertions).
I'd like to add that the reserve petcock take fuel from lower down in the tank, and is thus more susceptible to water collecting at the bottom of the tank. I suspect that water may have collected near your reserve tap, and when you turned it on, it sent water to the carbs, causing the engine to stop fairly quickly. Check for water remnants in your carb bowl
Good idea to take the tank off occasionally and flush it out with the petcocks removed, just to get rid of any water, rust flakes etc.
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 07-07-2008, 02:06 PM   #5 (permalink)
Favourite Bike: 1970 TR6 Spring Gold!
Ozbloke, what would you flush the tank with? I've been wanting to do this with mine but washn't sure how or whith what.
Hey, What's this oil on the floor?
quagmire is offline   Reply With Quote
00 tbs dies SPRINGER1978 Hinckley Classic Triples 4 01-25-2008 11:08 AM
T100 dies Delphilabs Twins Talk 8 08-07-2007 05:25 PM
'96 S3 Starts but dies hypocration T3 Sport / Touring Forum 7 07-10-2007 06:18 PM
Dies when put in gear Tre900 Hinckley Classic Triples 10 05-13-2006 07:06 PM
TBS ENGINE DIES keen Hinckley Classic Triples 4 02-11-2006 07:56 AM
