| Classic, Vintage & Veteran For Coventry and Meriden Models. Anything pre-Hinckley goes. |
07-05-2008, 11:54 AM
Supersport 400 Favourite Bike: 63 T120C Hardtail Rat
Posts: 92 Other Motorcycle: 74 Bonneville 750
650 Bonneville charging system troubles
hello finally joined up here, great info by your members and hope to contribute to this great resource. ok heres the problem;
the motor is a T120c its a 63 or 64 (not a preunit)
my battery is brand new and water is fine, i have rewired the whole bike and silver soldered and heat-shrinked all connections. how do i test the alternator?
i have a multimeter, the battery when charged is 12.5vdc
when running at high idle it reads 8.6vdc
i am assuming the drop is from the draw of the bike running with no charge comming in...
where do i start?
it has tympanium and boyer electronics.
these are both zip tied together underneath the gas tank, between the frames.
is this a bad place for them?
im also wondering if the tympanium is faulty. if i had some test procedures like resistance values or something i could figure this out.
the headlight doesnt go dim to warn me that the battery is going, it just cuts out and thats it, kapoot.
07-05-2008, 01:19 PM
Site Supporter SOTP Vintage Series Favourite Bike: '67 Triumph Bonneville
Posts: 7,674 Other Motorcycle: British Iron Extra Motorcycle: Dreer Norton Prototype
Check your Zener Diode, it might be shorted causing a charging "dump" to ground.
I don't have typaniumtroubleshooting guide handy, sorry.
07-05-2008, 02:19 PM
thanks, i dont have a zener diode, i think it may be removed because of the electronics modules. im new to some of the principals of them.
Too wierd to live, too rare to die.
My Bikes
07-05-2008, 03:54 PM
World SuperBike Favourite Bike: 2002 Triumph Trophy
Posts: 2,040 Other Motorcycle: 1970 Triumph Tiger 650 Extra Motorcycle: 1999 Yamaha Virago 1100
At the risk of having the "slings and arrows" visited upon me, let me ask the dumb question: "You do have the positive side grounded, don't you?"
No offense intended: Jim
Jim Ballard
07-05-2008, 04:57 PM
yes it is positive grounded, it runs fine it just doesnt charge.
jim: i couldn't get the archers and slingers out of bed so i guess you got lucky
My Bikes
07-05-2008, 05:25 PM
Production 125 Favourite Bike: 1972 triumph amen saviour
Posts: 9 Other Motorcycle: 1971 shovelhead rigid Extra Motorcycle: 1972 honda cb 450
i had a similar problem
i had a similar problem...first question...did you build the motor???second question...have you seen your stator??????..the reason im asking is...i did not build my motor...the same thing happened to me...whomever built my motor put my stator on backwards and my primary chain bit into my stator wires....my bike would run...because of my voltage regulator had a capacitor in it...but it wouldnt charge....so running at night was interesting...i finally found the problem recently when i had to take the whole motor apart because my rightside main crank bearing took a crap...look at your stator..it wont charge if its grounded out to your primary chain.........kingfish
LET GO OF MY EARS...I KNOW WHAT IM DOING!!!
07-05-2008, 05:50 PM
no i did not build it, i just got the bike, i have had the cover off, the wires looked fine. although there is alot of metal in the primary oil due to the very worn clutch shell and steels, i was wondering if the metal could cause problems with conductance. i will be pulling the cover off again to see if i can find anything obvious.
is there a way to test the alternator? like resistance readings?
thanks
My Bikes
07-05-2008, 09:05 PM
Formula Extreme Favourite Bike: 77 Bonneville
Wingnut,
Firstly, send me a PM or email with your email address and I'll send you a doc that may help.
GPZ - if the Zener shorts - it WILL take the fuse out immediately (in a blinding flash).
The alternator stator can be checked by:
- ign off
- fuse out
- disconnect the two wires from the alternator stator, where they connect to the Podtronics rectifier/regulator yellow wires.
- multimeter on low ohms range - 200 ohms
- measure between the wires going to the alternator - should see less than 2 ohms
- Meter in high ohms range - 20Mohms
- measure between one of the wires and frame/earth/battery +ve. Should see "1 blank" (infinite resistance) on meter.
If either of these readings is not right, the stator or wiring to it is faulty.
Pete
Per Ardua Ad Astra
07-05-2008, 09:21 PM
thanks very much i'll get crackin' on this first thing in the morning!
My Bikes
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Charging system
skipperspride |
Classic, Vintage & Veteran |
2 |
04-12-2008 03:14 AM |
Charging system?
chukus13 |
Speed Triple Forum |
1 |
03-29-2008 02:33 PM |
Charging system
m970456 |
1 |
03-16-2007 11:25 PM |
Charging system.
jtrip |
1 |
11-07-2005 11:56 AM |
charging system
Maintenance & Workshop Talk |
2 |
03-30-2005 05:40 PM |
