valve-rocker clearance
well, I dunno much but it seems they might be louder if you use half a flat to make .002. I don't think the thread pitch is any finer than 20 per inch. As long as you're at it, why not use a feeler gauge? Every dime store has em. Those valves are gonna be loud anyway, but if you use a gauge, you at least know they are close to spec. BTW, I thought .002 and .004 was the spec for 500's, but I never worked on a 650.
oops, just re-read your post and see you mean half a flat is .004, but unless the pitch is about forty-something you will still be over on the clearance. But better over than under, ain't it?
uh, ok, if the pitch is 20, you are close. Had to pencil this out. I should stick to asking questions!
Reason: error
