Old 03-27-2005   #1 (permalink)
Favorite Bike: 77 Bonneville
OzBloke's Avatar
Gents,
Need some help with my 76 Bonnie. Running Amal concentrics (Type 1's). Just stripped and reassembled cyclinders to find dreaded oil leak around exhaust tappet guide block. Fixed the leak, but noticed heavy carbon buildup on R/H piston - running rich?. When I got it back together, I tried to tune the carbs using technique in Haynes. L/H cylinder is fine, but R/H is really rough, and lots of black smoke. Adjustments (fuel/air and throttle stop) don't make any difference on R/H carby. Had to hold throttle open to about 1/3 to get it to run at all. Tried swapping bowls to see if it was float/needle problem - no difference. Jets checked - all OK. Blew out all cavities with compressed air.
Appreciate any suggestions.
Thanks
Pete
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 03-27-2005   #2 (permalink)
Did you check what your getting for spark on that cylinder????
Old 03-27-2005   #3 (permalink)
Favorite Bike: The 2 I Own
Other Motorcycle: 1977 Bonneville
Extra Motorcycle: '05 Rocket lll
How's the compression compare between cylinders? If Ok, does the carb slide stick anywhere in the carb, if so, it might be a warped carb body. I replaced both carbs on mine with NEW ones & haven't had a bit of trouble since! Now, a question for U. How'd U fix that exhaust tappet block leak? Did you have to pull the cylinders? I need to do the same thing but want to avoid more work than I have to! Thanks. Al
...and the Rocket's red glare
The jig is up.
The news is out.
They finally found me!
Styx... (Renegade)
Ride each ride like it may be your Last!
TRI-AL is offline   Reply With Quote
Old 03-27-2005   #4 (permalink)
OzBloke's Avatar
Tri-Al,
Yep, had to pull cylinders off. Problem was the (new) O-ring wasn't sealing in the cylinder base where the oil feeds the exhaust tappets. Had to use a bit of hi-temp silicone to seal between the o-ring and the flange. Be careful not to get any silcone below the o-ring. Also replaced bottom seal on the push-rod tube, and the o-ring inside the tube while I had it apart. Set yourself up with gaskets before you start - rocker boxes, head, cylinder base, and the seals. Also used a unique method of getting the pistons back in using only two hands (no good getting her indoors to help...). With cylinders off, take circlips out of the outside of the gudgeons, push gudgeons out from the centre till the pistons come off, leaving gudgeons in the outer side of the piston. Put pistons in cylinders, with the gudgeons jutting out. Place cylinders over the crankcase and conrods, line up the gudgeons with the conrods, and slide the gudgeons home. Insert circlips, then push the cylinders down to seat on the casing. Good luck.
Per Ardua Ad Astra
Old 03-27-2005   #5 (permalink)
OzBloke's Avatar
Found the problem. The needle & clip had got caught up in the throttle return spring, making it 1/2" higher than it should be. Lesson learned.
Thanks for your responses, guys.
Per Ardua Ad Astra
Old 03-27-2005   #6 (permalink)
Good one to remember
squod is offline   Reply With Quote
Old 04-04-2005   #7 (permalink)
hi just read this.happened on mine.needle had risen up due to me not fitting the clip properly.nice easy fix this time.cheers.geoff
rambo is offline   Reply With Quote
Old 04-04-2005   #8 (permalink)
Old 04-15-2005   #9 (permalink)
Had the same problem. Finally discovered the tit on the needle plate was resting on the slide boss due to me not fitting it right on reassembly. Tried to put the the slide in with out going to the trouble of removing the tank or brackets and slanting the carb body. Sent me on a goose chase. Haste make waste for sure.
okiecityflash is offline   Reply With Quote
rich or lean drock003 Twins Technical Talk 13 07-11-2007 12:49 PM
Lean Or Rich webonnielad Twins Technical Talk 15 05-06-2007 05:37 PM
Running rich? bonniegreen Twins Technical Talk 8 04-23-2007 11:58 PM
Running rich on the right quagmire Classic, Vintage & Veteran 21 10-03-2006 11:15 AM
Could it run better when much too rich? dazco Twins Talk 12 10-05-2005 11:29 PM
