Old 06-26-2008   #1 (permalink)
wobbly clutch basket
I just installed a new clutch basket in my 1960 bonne.
I put about 60 miles on it and it ran great. Went to check the primary chain freeplay and noticed the clutch basket was moving. I took the primary cover off to see what was up. I pulled on the basket and it moves in and out about a 1/16 inch maybe more. I also noticed that the chain rivits cut into the thin metal ring around the outside of the basket, but only on about 6 inches of the circumference. I took off the primary chain and kicked it over and the basket wobbles. I thought maybe the new basket was defective cause it wasn't straight to start with, so I put the old basket back on and kicked it over. Same thing, it wobbles. To get the back primary cover off I broke the hub that the basket's rubber splines on to. I used a home made puller. It snapped a piece of the back of the hub off so I welded an old socket to the hub with a nut welded to the top and put in a bolt and the hub came right out. Guess I should have bought the tool!! Turns out a new hub isn't available so my parts guy found me a used one. I didn't buy new bearing balls for the basket. Is the transmission shaft bent? Are the ball bearings bad? I also noticed that the basket cut a very fine line on the inside of the primary cover. The transmission seal doesn't leak. Should I just keep on riding this way or will there be a catastrophe?
davetile is offline   Reply With Quote
Old 06-26-2008   #2 (permalink)
sounds like a bent mainshaft.
i had the same prob. when the previous owner had the primary chain snap.
it winds around the clutch drum, and against the cover, and will bend the main shaft.
i would replace the mainshaft, otherwise, you will eat primary chains, clucth drums, and greatly increase your chain of the primary chain breaking.
NHOJ from Maine is offline   Reply With Quote
wobbly clutch basket davetile Classic, Vintage & Veteran 0 06-23-2008 09:07 PM
Clutch basket removal 666Bonneville Classic, Vintage & Veteran 6 06-09-2008 03:35 PM
Wobbly with Pillion chedd Twins Talk 14 12-06-2007 10:58 PM
outer clutch basket play CharlestonRider Modifications & Workshop Talk 5 07-04-2005 10:23 AM
Hayward belt drive clutch basket Cuppa500 Classic, Vintage & Veteran 1 01-17-2005 06:15 AM
