My pre unit oil pressure gage also tends to peter out as the temperature rises. This is normal, but should indicate some pressure.Watch it returning into the tank and if your rocker box shows some seepage it's fine! As far as leaking oil, good luck stopping it. I had so many leaks, I've had a lot on this particular bike. The rubber inside the oil pressur gage gave out and made a mess. I've been told that a pressure relieve valve w/o the protruding indicator can be used.
If you think the oil pump is leaving more oil in the case than it pumps out, I would think that eventually all of the oil would fill up the crank, and that could be a cracked return pipe . If it is circulaing, it's most likely okay. My bike leaks a tablespoon or so after every ride, but I believe it is a result of a lot of minor leaks combined . Ive haven't sucessfully stoped the sump pump access so a little comes from there, some comes from the timing side by the generator, some from the vertical split cases and blows around collecting under the motor. A small crack in the primary case dosen't help either.
Even after all of these minor leaks, I can,t tell if the breather leaks at all! It proboaly puts a mist out and collects under over sideways down! Well , that's my experience so far . Iv'e had better oil tight bikes with the unit construction.
