Answered your own question there, Davetile. If the residual oil level is high, there can only be two reasons for this. Firstly, the pick up pipe in the sump has fallen out or secondly and more likely, the scavenge side of the pump can't move it quick enough. Add to that the pressure side being worn and allowing by pass while the bike is standing, you will initally get oil / emulsified oil on first start up from the breather. Another thought........... has the gasket for the oil pump been fitted incorrectly, covering a port??????
Roy.
