Valve clearance
Hi timwil, My 1959 T100 has the ramp (high lift) cams fitted and I set the valve clearance at .004" inlet and .006" exhaust. Setting at the listed .010" on both inlet and exhaust makes for a noisy top end. I started with reducing the clearance to stop the noisy tappets and have found that running at .004" and .006" the bike ran fine without any ill effects.
The T100 is an all alloy engine so the valve clearance needs to be greater than those fitted with cast iron engines, speed twins have cast iron engines, so your friend with the speed twin, the setting is correct.
Regards MikeT150
