Old 06-10-2008   #1 (permalink)
Favorite Bike: 1979 Bonneville 750
Not running on both cylinders
I got a 79 bonne 750 and I just put the carbs back together, and when i fire it back up it will run on both cylinders for a bit and then it drops down to one. Do i need to have carbs tuned? Im kinda at a little wall here
Mrsinister is offline   Reply With Quote
Old 06-10-2008   #2 (permalink)
Favorite Bike: 1970 T120R(unrestored)
Other Motorcycle: 2002 Bonneville
Extra Motorcycle: 1970 T120R(restored)
Same problem,but in my case it turned out to be a bad plug.
Just music and my motorcycles. Thats all I need.
retrobiker is offline   Reply With Quote
Old 06-11-2008   #3 (permalink)
Obvious one
This may be too obvious, but are they both getting enough gas? It could be a restriction in one of the lines or fittings is preventing adequate gas flow to that carb.
503_colville is offline   Reply With Quote
Old 06-11-2008   #4 (permalink)
Im trying new plugs and wires, the wires havent been replaced in a while as the look of them, the fuel lines are clear tube minus a aluminum fuel filter, I think im getting equal fuel on both sides. But that might be something I should just put into the just because it could save me money bin.
Nikasil cylinders mikey Speed Triple Forum 6 12-24-2006 06:33 PM
Cylinders stuck... LukeMac Classic, Vintage & Veteran 6 12-18-2006 11:15 PM
3 Cylinders? Why... Linz Daytona Deliberations 2 11-04-2006 11:46 PM
running on 2 cylinders? buzlin Speed Triple Forum 13 02-04-2006 11:34 AM
Why 3 cylinders? EricMichael Hinckley Classic Triples 6 01-31-2005 07:00 AM
